Assuming you are confident you did it correctly, I'd first be curious as to the smallest gauge size you used...just to make sure. If, in fact, you're pretty much down to zero...I'd listen to 124 (he know's what he's talking about.) I've had my bike since May. I'm not a track racer (bike has only seen the track once and that was for fun,) have done a couple Harescramble/Enduro events, and mostly ride woods. My valves haven't budged...I just checked them last weekend.NoWheeler wrote:....what do i do when i can't fit the smallest gauge into the intakes?
sI thought the owners manual was pretty darn good,too,and that video Ken has is really outstanding.Be sure of your technique when checking those intakes. Also, make absolutely sure your piston is in the correct position. I have found the owners manual (rather than the shop manual) more handy for instructions on checking/shimming the valve
This is a big ditto! My bike usually starts well within 5 kicks (more like 2 or 3.) Lot 'o kicks to get it started is a sign of scary things to come.[email protected] wrote:How was your bike running? If it started easily and ran fine your intakes weren't at zero,instead there was a measuring error.
Evan, if I were you, make sure the mechanics note on the ticket the before and after clearances and any shim values they claim had to be installed (if any.) Then, I would take the bike home and not even think about riding it until you've had a chance to tear that cover off and check the valves yourself. At least this way, assuming the dealer did their job correctly, you'll know EXACTLY what properly adjusted valves feel like when checking them. It will sure help to take the guesswork out of how they should "feel" when working with the feeler gauges.[email protected] wrote:Well Evan, I hope you can trust that shop...
