05 450x jd jet for ocotillo
  • No. 9
    by No. 9 » Mon Jan 08, 2007 9:47 pm
    Help I am opening the air box and adding a jd jet kit and twin air filter w/o backfire screen. Does any one have a good setting out of the box for ocotillo. Also will I have to adjust for Dove Springs/ California City and if so what there??
    Where did they go boss?
    by Asmith » Mon Jan 08, 2007 9:54 pm
    165 or 170 main.
    Red Needle 4th clip
    Fuel screw at 2 turns out.
    Should get you close.
    Dove shouldn't be much different.
  • No. 9
    by No. 9 » Mon Jan 08, 2007 10:08 pm
    thank you I am looking forward to the change in the bke as everyone claims will happen. by the way there is talk about running a full quart of oil in trans side what do you think??
    by Asmith » Mon Jan 08, 2007 10:15 pm
    stconklin wrote:thank you I am looking forward to the change in the bke as everyone claims will happen. by the way there is talk about running a full quart of oil in trans side what do you think??
    I agree! I do in my 450X and about 880ml in the 250X.
  • No. 9
    by No. 9 » Tue Jan 09, 2007 12:31 pm
    the benefit of this is???
    by Asmith » Tue Jan 09, 2007 5:45 pm
    stconklin wrote:the benefit of this is???
    There have been a FEW riders that have experienced transmissions locking up due to lack of lubrication.
    All have been guys riding on smooth roads at high speeds.
    The 450X tranny is designed to splash the fluid on the geartrain. This is easily accomplished by going over bumps. Some guys would rather ride their 450X's on pavement. In this scenario the gears don't get lubricated and lock up.
    The 07 models have groove cut into the gears to fling oil at any speed and terrain.
    The simple fix is run a full quart.
