First ride on my 250x
  • jerrypc69
    by jerrypc69 » Sun Jan 07, 2007 8:24 am
    Just came back from my first ride on this bike .
    All I can say is less is definitely more.
    Laughed soo much at my buddys trying to keep up in the wet and muddy woods here in the UK on there 450's .
    I think i'm going to like this bike :lol:
    by Asmith » Sun Jan 07, 2007 8:44 am
    Is it still stock, or have you done any mods yet?
  • jerrypc69
    by jerrypc69 » Sun Jan 07, 2007 8:52 am
    It's still stock thats what makes it even funnier. :lol:
    Will be ordering some jets tomorrow and opening the airbox next weekend ,just wanted to ride it stock to see how much the mods would change it
    by Asmith » Sun Jan 07, 2007 9:05 am
    Your buddies aren't gonna want to ride with you anymore.
    Especially once you open it up a bit...
  • jerrypc69
    by jerrypc69 » Sun Jan 07, 2007 9:15 am
    What would you advise on jetting
    I am just going to open up the air box take the flametrap out and fit twin air filter.
    I don't think need mess with the pink wire and dont want it any noisier.
    Most riding done at 0-1000m above sea level
    by Asmith » Sun Jan 07, 2007 9:20 am
    jerrypc69 wrote:~
    Do that and get the JD Kit. Makes things easy.
    If you just want to do it on your own do this:
    Change the needle to the 4th clip.(stock 2nd clip)
    Change the main jet to a 158.(stock 130)
    Change the pilot jet to a 42.(stock 40)
    Open fuel screw to 2 turns from all in.
    Makes the bike run way better, start easier and makes a bunch more power.
  • jerrypc69
    by jerrypc69 » Sun Jan 07, 2007 9:22 am
    Thanks
    I will try that next week
    KevinM
    by KevinM » Mon Jan 08, 2007 7:59 am
    He ain't kidding Jerry. Those carb changes will make a big difference.
    Starts much easier. 10-20 secs with the choke on, then idles almost like it had an EFI system.
    I'm running larger main jet (162) because I have opened up the airbox and am running a White Bros E2 exhaust w/o the spark arrestor.
    09 CRF 450R
    07 CRF 250R
    FS 2 trns
    05 CRF 250X
  • jerrypc69
    by jerrypc69 » Mon Jan 08, 2007 10:45 am
    Right jets ordered and on there way
    purchased the filter today
    time to get out in the garage and start stripping the crf
    now where is that dremil :-k
    crf~rob
    by crf~rob » Mon Jan 08, 2007 11:21 am
    Gonna start work on mine today! Thanks to the help from ~ it should be a breeze. I plan on basically doing exactly the same mods as you....except i'm adding the smog block off kit also!
    Happy riding
    crf~rob <Cali>
    06 CRF250X
    04 CRF50F
    03 CRF230F
    06 Pit Bike
  • jerrypc69
    by jerrypc69 » Thu Jan 11, 2007 11:41 am
    I have been advised to do the AP mod do you think its worth it considering the rest of the mods I am going to do :?:
    by Asmith » Thu Jan 11, 2007 12:51 pm
    jerrypc69 wrote:I have been advised to do the AP mod do you think its worth it considering the rest of the mods I am going to do :?:
    It's easier to do while you are in there. And its easy to just do the o-ring part (that's all most of us do).
    I have the whole mod on PDF. PM me with your e-mail and i'll send it to you.
  • jerrypc69
    by jerrypc69 » Thu Jan 11, 2007 2:59 pm
    Thanks ~
    will this do the same job as the boyesen accelerator pump cover :?:
    by Asmith » Thu Jan 11, 2007 3:04 pm
    jerrypc69 wrote:Thanks ~
    The AP mod will eliminate the off idle bog.
    The Boyesen AP cover is designed to refill faster than the stock cover. The fuel supply for the AP is in the cover.
    If you are constantly pumping the throttle, you can use up the fuel supply faster than the stock cover can refill and thus not get consistent shots of fuel.
    The Boyesen cover is designed to fix that. I think only MX racers would ride in such a manner to need the Boyesen.
  • jerrypc69
    by jerrypc69 » Thu Jan 11, 2007 3:15 pm
    Thanks again ~ your a wealth of information
    I did a little searching on this site which has educated me lots on the subject
