skiiers / boarders
  • skiier or boarder
    skiier
    5
    63%
    boarder
    3
    38%
    Total votes: 8
  • _06_crf_250r
    skiiers / boarders
    by _06_crf_250r » Fri Jan 05, 2007 12:54 pm
    Since there is not much happening in the bike portion of my life I thought I would start a topic on skiing. So Where do you guys ski or board?
    Shredder or skier?
    what kind of conditions does you mtn have now?
    What equipment do you have?
    Any other stories about skiing or boarding.
    I Ski at Titus mountain NY the conditions are not bad but we had to close today due to the warm weather.
    I have blizzard skies and bindings and dalbello boots.
    Don't really have any stories I can think of right now.
    06 crf 250r
    WB Carbon Pro
    AC subframe
    Pro Taper Contour
    Cycra powerflow fender
    Twin air filter
    works conn radiator braces
    works conn skid plate
    hammer head case saver
    renthal red 49tooth rear sprocket
    renthaul gold chain
    High Flyer
    by High Flyer » Wed Jan 10, 2007 5:37 pm
    I've snowboarding since 1999 here in New Brunswick Canada
    The ski hill i snowboard at is Poley Mountain, located about 20 mintues from where i live. they have about 23 trails.
    2004 CRF150
    -Pro-Taper SE CR low bend
    -Michilen MS2's
    -RK MXZ3 Chain
    -Pro Taper gray waffel grips
    -Air Box cover removed
    -JT 48T Rear Sprocket
    BigD
    by BigD » Wed Jan 10, 2007 7:39 pm
    Snowboard......the only way to go!
    Actually skiing is great, but too many moving parts! Plus I used to skateboard a ton when I was younger, so it was an easy transition.
    I'm riding a 163 LibTech Pacifier, Kirkwood is my home mountain. Great terrain, lots of steep.
    2006 CRF 250x
    JD Jet, GPR Stabilizer, Bafflectomy, no backfire screen, 13/51 gearing, oil slick, smoke screen, heat seeking missles, twin 50 cal.'s, etc...
