Four-Fifty-X wrote:I have read hear and other forums that running 22mm offset clamps helps handling.
Several questions:
1-what exactly does offset mean in this regard? Is it the distance between the plane of the forks and the plane of the spindle?
2-what is the stock offset? 24?
3-does the 22mm set improve straight line stability or turning?
4-what is a good brand?
Thanks.
Skoot22 wrote:XGiant wrote:I am having my suspension done at the moment. The guy that is doing it said that on the 2005 models (450X), he actually adds a spacer that lengthens the shock and raises the rear of the bike 10mm. He says that this makes a huge difference in the way the bike turns. I assume that the 22mm offset clamps do the same type of thing.
sounds like an inexpensive alternative
XGiant wrote:Skoot22 wrote:XGiant wrote:I am having my suspension done at the moment. The guy that is doing it said that on the 2005 models (450X), he actually adds a spacer that lengthens the shock and raises the rear of the bike 10mm. He says that this makes a huge difference in the way the bike turns. I assume that the 22mm offset clamps do the same type of thing.
I was just impressed with the fact that my tuner knew the '05 450X well enough to address this deficiency through revalving. Have I adequately plugged House of Horsepower...? That is House, H-O-U-S....
http://www.houseofhorsepower.com/index.htm
~ wrote:paul turner wrote:Forgive Smash, Doug. He's a man of few numbers, easily mixed up. more familiar with numbers such as 9mm, .243, .308, 36-24-36 and the like.
Fixed
[email protected] wrote:Forgive Smash, Doug. He's a man of few numbers, easily mixed up. more familiar with numbers such as 9mm, .243, .308, 36-24-36 and the like.
I figured him as a gun loving,right wing extremist,sexist too.
That's why I can't wait to meet you guys !
So, there ARE real men in California :D
There's hope for the country yet. Doug
