One more whack at the dead horse called "airbox"
  • johns230
    by johns230 » Fri Dec 29, 2006 9:09 pm
    I know I know.... do a search. I did and I couldn't find what I was looking for. All I would like see is a picture of what the mod to the airbox looks like. Some say "cut", and some say "remove". Am I cutting a hole? Or is there simply a potion of the box that should be removed? What exactly should it look like when it's done?
    Thanks
    Sorry, I didn't know you couldn't delete posts. I started another one with pics on the same subject. Mods, can you please delete this one?
    JimmyPwadd
    by JimmyPwadd » Sat Dec 30, 2006 12:50 pm
    Mr Smith wrote:I finally did it...And im very very pleased with the results! Cant wait to ride Friday baby!
    Here are some good pics from Mr. Smith...
    Drill out the rivets and remove the snorkel. Then use a dremel tool or something along those lines to cut away the top of the air box. ( I carefully used a sawzall with a short metal blade) I left my air box in the bike and air filter in as not to get shavings in my carb, be careful not to hit your air filter. When your done pull it out and blow off your filter. Removing you backfire screen will make it breath a lot better too.
    If you do this mod you will need to adjust your jetting. JD Jetting has all your jets/ needles and simple instructions. HIGHLY recommended!
    2006 CRF250X
    Boyesen Quick Shot /AP mod
    by Asmith » Sat Dec 30, 2006 1:01 pm
    JimmyPwadd wrote:Drill out the rivets and remove the snorkel. Then use a dremel tool or something along those lines to cut away the top of the air box. ( I carefully used a sawzall with a short metal blade) I left my air box in the bike and air filter in as not to get shavings in my carb, be careful not to hit your air filter. When your done pull it out and blow off your filter. Removing you backfire screen will make it breath a lot better too.
    The CRF 230F box is a little different but the process is the same as Jimmy has described.
    The JD Jetting is not available for the CRF 230, so you will need to source the main jet, pilot jet and power up needle from Honda.
  • johns230
    by johns230 » Sat Dec 30, 2006 10:35 pm
    Wow! Great shot of the airbbox. I get the idea now.
    Thanks,
    John
    JimmyPwadd
    by JimmyPwadd » Wed Jan 03, 2007 11:06 am
    Oops, I didn't see the 230F..DOH!
    2006 CRF250X
    KRCRFs
    by KRCRFs » Thu Jan 04, 2007 6:38 am
    That looks like the 250/450X airbox mod not the 230F mod.
    Kim's: 04 250X
    13/51 with +11
    Main Jet: 138
    Air Screw: 2.5 Turns
    Kathy's: 04 230F
    13/48 sprockets
    Main Jet: 132
    Air Screw: 1.5 Turns
    Common:
    Pilot Jets: 42
    Stock Needles: 4th Pos
    No Screens or Baffles
    Open Air Boxes, Twin Air Filters
