carb?
  • beerhunter
    carb?
    by beerhunter » Fri Dec 29, 2006 6:04 am
    Where can I pick up the hex head screws for the bottom of my carb.?
    I have nearly stipped the heads on the stock phillips head screws from all the MFing jetting.
    thanks for any help,
    by Asmith » Fri Dec 29, 2006 6:07 am
    Maybe an auto parts store? NAPA auto parts? Orchard Supply Hardware?
    These are the sizes:
    Idle-adjust bracket - replace stock screw with M4x10 and M4 lock washer.
    Float bowl - replace four stock M4x14 screws with M4x16 screws (no one seems to stock the M4x14 in stainless) plus M4 lock washers. If you don't use lock washers, one of the M4x16s will not fit; use an M4x12 instead.
  • beerhunter
    by beerhunter » Fri Dec 29, 2006 6:24 am
    THanks,
    just ask for metric hex head 4 x whatever ?
    by Asmith » Fri Dec 29, 2006 6:33 am
    beerhunter wrote:THanks,
    Try to get metric Stainless steel Allen head Cap screws.
    The Black oxide ones are easy to find, but they might rust a bit.
  • beerhunter
    by beerhunter » Fri Dec 29, 2006 7:23 am
    Thanks man
    by Rhoghead » Fri Dec 29, 2006 8:05 am
    Nut & Bolt Stores have good stock of Stainless Stuff............... :mrgreen:
    by Old Dude » Fri Dec 29, 2006 9:47 am
    Got mine at Ace Hardware.
    higlet
    by higlet » Wed Jan 17, 2007 10:07 am
    Mcmaster Carr at http://mcmastercarr.com has any and every nut bolt screw of every grade material available. They ship super fast, I think once I actually got something the same day I ordered it or first thing the next morning.
    by Old Dude » Wed Jan 17, 2007 8:41 pm
    Ace (Hardware) is the place I got mine. I got the rounded head ones which give you even more room to work.
