~ wrote:Getting to the carb:
Remove gas tank and seat. Top of carb can be accessed now to do the needle.
Rear subframe is easy to lift. Loosen clamp on rear carb boot, loosen top subframe bolt, remove two exhaust bolts, remove two lower subframe bolts.
Rotate subframe straight up and tighten upper subframe bolt to hold in place.
Loosen front carb boot and now carb can easily be rotated for access to bottom.
Dust Devil wrote:~ wrote:Getting to the carb:
Or you could just loosen the two clamps and rotate it without doing all that other stuff.
