need help with sprockets
  • dtrider4ever118
    by dtrider4ever118 » Sat Dec 02, 2006 3:09 pm
    ok i got a new sprocket (51 tooth from jt) and it doesnt fit. i got the chain on and it was grinding on the chain-stay thing so i took that off but i cant get the wheel to pull back far enough to slide the axel back in and the chain does have some slack(probably right around what its supposed to have) with the wheel forward
    thanks for helping
    04' crf150f
    white bros. r4 pipe
    white bros. power filter
    bbr rev box
    12 tooth jt front sprocket
    102 main, 45 pilot
  • dk54red
    by dk54red » Sat Dec 02, 2006 6:24 pm
    you need to replace the chain and measure out a new chain link. Lay them down and add the extra 3 teeth. I'm guessing three. You have a 51 and stock on a 03-05 is a 48 and would be three. Stock on a 06-07 is a 47 and would be 4 which in pretty big jump. You should always replace the sprockets (front and back) and the chain so they can wear together. You could damage your new sprocket with the old chain if its streched out bad.
  • dtrider4ever118
    by dtrider4ever118 » Sat Dec 02, 2006 6:40 pm
    ok my old rear sprocket is in good shape i got the bigger sprocket for some indoors races but what should i do about the chain guard thing the sprocket grinds on it should i just take it off???
    and for a chain what is better for racing an oring or non oring
    04' crf150f
    white bros. r4 pipe
    bbr rev box
    102 main, 45 pilot
  • dtrider4ever118
    by dtrider4ever118 » Sun Dec 03, 2006 6:33 am
    ok im just gona drop a tooth on the fron sprocket and leave the stcok sprocket on the back but i still have the question about the chain oring or non-oring i know the difference but which is better for racing???
    04' crf150f
    white bros. r4 pipe
    bbr rev box
    102 main, 45 pilot
  • dk54red
    by dk54red » Sun Dec 03, 2006 7:07 am
    I prefer the non 0-ring. It's more maintenance, but I feel it's worth it. Just clean it more. If you get the right size (length) chain it shouldn't grind. I like the 520 gold race chain by rk.
  • dtrider4ever118
    by dtrider4ever118 » Sun Dec 03, 2006 2:11 pm
    ok thanks alot for the help
