Enclosed Trailer Help...Floors
    Jut8
    by Jut8 » Sun Feb 13, 2005 7:18 pm
    Hey guys, i hope someone can help me out with this
    quick. I just bought and enclosed trailer from Lowes,
    and i want to use it these comming weekend to go down
    to budds creek.
    Here is my question, the floor is treated plywood, what
    would i use to seal it up, so if fuel or oil is spilled, it
    wont soak into the floor. I had a couple of ideas; either
    using Thompsons water seal, or purchasing the
    rustoliem Epoxy garage floor paint with the traction
    chips. Has anyone ever done this before or have any
    suggestions? If so, please let me know. Thanks in
    advance!
    --Justin
    -08 CRF50f
    -03 XR50
    -13 Foreman 500
    -07 DRZ400s
    -03 XR100r
  • ev
    by ev » Mon Feb 14, 2005 4:27 am
    are you worried about the 'lifespan' or about optics?
    as long as you are not spilling gallons of gas do not worry about your floor,
    if you really want it to last forever cover your floor with a "Schalungsplatte" lack of tech. terms sorry :roll: dark brown laminat covered birch plywood, one side rough silkscreen surface, mostly fabricated in Finnland
    systemnt
    by systemnt » Mon Feb 14, 2005 10:41 am
    Treat the existing bare floor (assuming its bare plywood and not already treated) with a water sealer, then purchase some inexpensive linoleum (or expensive if you prefer), and carpet/tile glue.
    cut the linoleum to fit your trailer in one sheet , lay down the glue.. lay down the sheet, smooth out with a roller or your hand... let dry for a few hours..
    (i suggest the checkboard -black white squares for that racing look)
    Its relatively inexpensive, protects the wood floor, and looks good, as well as provides a smooth easy cleanable surface.
    2003 CRF450R (mine)
    2003 YZ250F (mine)
    2005 CRF230F (mine)
    1985 CR250R (mine)
    2004 YZ85R(kiddos)
    47cc GT Pocket Bike (38mph)
    47cc 'Cane Pocket Bike (46mph)
    1 large box of band-aids
  • redrider911
    by redrider911 » Mon Feb 14, 2005 2:25 pm
    I have tried a few different kinds of flooring. The plain plywood is, well, plain. A motocross trailer needs to have black and white checkered. The first time I used the cheap vinal tiles, the ones where you peel the paper off the back and stick them to the floor. No good. The second a drop of gas spilled out the carb vent and onto the floor, it was junk. The summer heat also made it peel up. It gets really hot in there with the doors closed during the week. Next, I tried a one piece that came in a roll. It was harder to fit and center. I never done that before. I only got one season out of it. The material just did not hold up. It got scratched and torn and looked really bad. Finally I went out and bought commercial grade vinal tiles. These are 1 foot by 1 foot square, are easy to install with the proper glue, and have lasted three seasons now. After you put the floor down and the glue has dried, put a few coats of wax down to protect it and seal the seams so gas won't get under it. I strip the wax every spring clean it and rewax a few times. It still looks good. The commercial tile has the color all the way through so if it scratches, you wont notice it as much. Good luck! ps i would put a roof vent in that oven on wheels!
    Jut8
    by Jut8 » Tue Feb 15, 2005 4:25 am
    I do have a roof vent on the trailer, thank god it came with it! I can see tha thing becomming an oven in the summer. As for the commericial grade black and white checker tile, where did you get it at and how much did it run you? Also, how long was the install, and how long did it take to setup and cure?
    Another thing, i am going to budds creek this weekend, so if i just coat it up with a watersealer ( i was thinking thompsons unless some has another idea or company ) will i be able to tile it after that. Any and all help is appreciated i am leaving saturday morning, so i would like to have it all taken care tonight or tommorrow if possible because that is the only 2 days we are supposed to have good weather here in Pittsburgh this week.
    -08 CRF50f
    -03 XR50
    -13 Foreman 500
    -07 DRZ400s
    -03 XR100r
  • redrider911
    by redrider911 » Tue Feb 15, 2005 7:09 pm
    Jut8...I bought the stuff at Carpet Castle. It's a store that sells flooring. I did not find it at Home Depot. I bought one box of each color. That was enough for a 6 foot by 12 foot trailer. 6 times 12 equals 72, so i used 72 squares. Ok 80, I made a few mistakes. I still have a lot left over. I think i paid 70$ a box, but dont quote me on that. Glue was 15$ i think. The tiles are not true black and white. There are other colors mixed in to help hide any dents and scratches. It took me 4 hours. I also put down several coats of wax and each coat took a little time to dry. Make sure you measure your trailer. U can't by individual tiles, only boxes. If your gonna put tile in when u get back, I would not spend the money on sealer for just one ride. Make sure the bottom has protection. My trailer came painted black from the factory. If i remember right, U PA guys use a lot of sand on the roads. When it comes time to installing the tile, make sure floor is clean and dry. Someone at the store can answer questions on install. Have fun at Budds Creek. I thaught they were plowing snow off of it last weekend. I go to NEMX, an indoor place at Ohio Pa border. No snow there!
    Jut8
    by Jut8 » Wed Feb 16, 2005 4:30 am
    You go NEMX?! I am there every week on thursday or friday!! That i freakin awesome, i am going to try to get up there this thursday before the race, dont tell me you ride the the CRF with the Carbon pro and the #1 or #10 plate on the side, if you are, you are fast as hell! Anywho, let me know next time you go up there, i ride an 02 CRF450, with the #8 on the side if you see me up there, let me know who you are. You wanna head to budds this weekend? My other buddies were down there last weekend, they said it was perfect, they go up to NEMX also, the both ride YZ250F's, #7 and #5, they are alot fast than me though, i need to get back into shape, lol! Anywho,i hope see you up there.
    -08 CRF50f
    -03 XR50
    -13 Foreman 500
    -07 DRZ400s
    -03 XR100r
  • redrider911
    by redrider911 » Wed Feb 16, 2005 3:18 pm
    I go to Nemx to watch my friends right now. Im hopeing to get my 05 450 this weekend. Never really rode a thumper b4, except putting around. Im not fast at all, just a mid pack b class rider (on a 2 stroke). that would b cool to come out to Budds Creek. Hopefully real soon. My friend owns a race track called Area 51 in Batavia, Ny. You probably seen a window sticker on a truck at nemx. i will e mail you when i go.
  • redrider911
    by redrider911 » Wed Feb 16, 2005 4:09 pm
    oh yeah, nemx is a 2 hr drive for me. I only get to go if i get out early which rarely happens. Budds creek is 8 hrs if i dont get lost. This requires camping. I put a vent free heater in my trailer, but its still way too cold to go this time of year. You gotta try area 51 this year. its a new track kinda built like red bud mx. you can walk under the track through tunnels. its less than 3 hrs from nemx. camping is allowed saturday nights
    Jut8
    by Jut8 » Wed Feb 16, 2005 7:22 pm
    Yeah would definaly like to try that, out! You say your
    not fast, i WISH i was mid pack B rider, im a mid pack
    C, but i hope to get back in shape and be in B by the end
    of the summer.
    Anywho, about that track, i would like to come up and
    check out, i see your are from buffalo, i have family up
    there, they live in Orchard Park, right by Green Lake.
    I go up there atleast 3 time a summer to hang out with
    them. Have you ever had Antionettes ice cream, i love
    that stuff, i wish we had one here in PA!
    -08 CRF50f
    -03 XR50
    -13 Foreman 500
    -07 DRZ400s
    -03 XR100r
    by 124 » Thu Feb 17, 2005 1:08 pm
    Before you use anything on treated lumber, you need to verify that the wood is dried out. Treated lumbar is "wet" when new. Just like a deck...the wood needs to dry before sealant can be applied (or any chemical for that matter) Drying time is dependent on age and atmosphere over time. Just make sure the wood does not feel "soft"...
  • redrider911
    by redrider911 » Thu Feb 17, 2005 3:03 pm
    Jut8 DUDE I live 5 min from green lake!! right down orchard park rd in west seneca. Do u trail ride? I wanna go to rocky gap and mearienville trails this summer. My friend knows ia guy in Bradford that has some sick enduro trails that would make Scott Summers sweat! Im off on weekends so maybe nemx on saturday sometime soon. Need to disassemble bike and grease and put some goodies on b4 I ride it.
    Jut8
    by Jut8 » Thu Feb 17, 2005 6:07 pm
    Dude, thats freakin sweet. Yeah, we will definatly have
    get together sometime. I would be up for doing some
    trails for sure, NEMX is a definate though. My uncle lives
    on Regalwood Dr. if you comming past the country club
    toward bihrs convience store, make a right there, and
    then and the another right about 3/4 of mile down that road, and they live on regal wood dr. My cousin actually plays hockey
    for the west seneca wings hockey team.
    Yeah we always go up there alot in the summer, atleast
    3 or 4 times a summer, i took ride up there on my GSXR
    last summer, it was sweet, but i never had the dirt bike
    up there, so it would be cool to bring it up and do some
    ridding up in buffalo.
    -08 CRF50f
    -03 XR50
    -13 Foreman 500
    -07 DRZ400s
    -03 XR100r
    hotrod
    by hotrod » Tue Dec 06, 2005 1:06 pm
    I bought an enclosed trailer that had belonged to a lawn service. It had a stained PT plywood floor. Good old Porch paint (grey) was applied (2coats) along with some flat white on the walls. It brightened up the trailer, stayed up well, and was pretty cheap. It actually covered the oil type staining on the floor.
    2005 Honda CRF230F
    2006 Honda CRF50
    2003 Yamaha PW50
    2003 Harley Davidson Road King
