Index: Carb Jetting Database
  • thebob_za
    by thebob_za » Mon Nov 12, 2012 12:59 am
    Year: 250X 2007
    Elevation: 5000 - 6000 ft
    Temperature Range: 60 - 110 F
    Smog (AIS): N/A
    Airbox Modified Top: Yes, though not full 4x4
    Airbox Modified Sides: No
    Backfire Screen: Removed
    Air Filter: Twin Air or No Toil
    Pilot Jet: 42
    Main Jet: 158
    Needle: JD Red
    Needle Clip Position: 4th
    Fuel Screw Type: Sunline
    Fuel Screw Setting: 2 turns
    AP Modified: 2008 update kit
    Leak Jet: Stock
    AP Cover: N/A
    Exhaust Type: RaceTec slip-on and 'R' header
    Exhaust Modified: No
    Pink Wire Modified: No
  • wingdude
    by wingdude » Fri Jun 14, 2013 8:48 am
    Year: 2005
    Elevation: 0-2500
    Temperature Range: 48-85
    Smog (AIS): None
    Backfire Screen: Stock
    Air Filter: Stock
    Pilot Jet: 42
    Main Jet: 158
    Needle: Red
    Needle Clip Position: 5
    Fuel Screw Type: JD
    Fuel Screw Setting: 1.75
    AP Modified: No
    Leak Jet: Stock
    AP Cover: Stock
    Exhaust Type: Stock
    Notes: Bike runs way better than stock with JDJetting kit. Fired right up and ran great immediately after JD kit installation & air box mod.
    riddler9
    Re: Index: Carb Jetting Database
    by riddler9 » Mon Jun 24, 2013 11:13 am
    DISCLAIMER: '09 R head and cam, 13:5:1 piston. First section is base setup on pump gas. Mix section is for a race mixture.
    Year: 2009
    Elevation: 5000-10,500
    Temperature Range: 45-105
    Smog (AIS): gone
    Airbox Modified Top: yes
    Airbox Modified Sides: no
    Backfire Screen: gone
    Air Filter: Twin Air, Twin Air Power Flo cage, No-Toil Red oil
    Pilot Jet: 42
    Main Jet: 175
    Needle: JD Red (for the X, not the R)
    Fuel Screw Type: R&D Flex
    Fuel Screw Setting: 2-1/8 to 2-1/2 depending on alt/temp (2.5 @ 90F/5,000')
    AP Modified: no
    Leak Jet: meh, adjustable - think 1-1/2 turns
    AP Cover: R&D Power Pump II
    Exhaust Type: Pro Circuit TI Header and T-4 Muffler
    Exhaust Modified: Bolt-on's listed
    Pink Wire Modified: yes
    Mixes
    ratio 3:1:1
    91 octane pump : VP U4.4 : VP T4
    4000' @ 90F drop main jet to 170
    6000' @ 90F drop main jet to 165
    Official Lurker
    oscarbella
    Modified Jetting
    by oscarbella » Tue Jan 07, 2014 10:56 pm
    Updated jetting with the fitment of a 270 big bore kit, interesting to note that the main jet is now 158 vs 165 with the stock cylinder.
    Big bore creates more suction so uses smaller jets.:)
    As per usual, the guys at JD Jetting were spot on with their Jetting recommendation.
    Year: 250X 2007
    Fitted with Cylinder Works 270 big bore kit
    Smog (AIS): N/A
    Airbox Modified Top: Cutout in frame
    Pilot Jet: 42
    Main Jet: 158
    Needle: JD Red
    Fuel Screw Type: Zip Ty
    Fuel Screw Setting: 1 1/2 turns
    AP Modified: N/A
    Leak Jet: Stock
    AP Cover: N/A
    Exhaust Type: Yoshimura RS2 Stainless Slip on
    Pink Wire Modified: No :D :D
    '07 CRF250X
    Cylinder Works 270 Big Bore kit
    Kibblewhite Black Diamond VAlves and springs.
    JD Jet Kit + CCC Airbox Mod
    Yoshimura RS2 Slip on.
    '07 CRF230F - stock standard (Sold)
    '07 CRF150RB - The Youngsta's Ride (Sold)
  • jpcullen70
    by jpcullen70 » Wed Jan 08, 2014 5:18 pm
    Year: 2005
    Elevation: 2,500 - 6,000
    Temperature Range: 50 - 110
    Smog (AIS): No
    Backfire Screen: Yes
    Air Filter: Stock
    Pilot Jet: 42
    Main Jet: 160
    Needle: Red
    Fuel Screw Type: CRF's Only
    Fuel Screw Setting: 1 3/4
    AP Modified: No
    Leak Jet: 55
    AP Cover: No
    Exhaust Type: Stock
  • hall_philip
    by hall_philip » Sun Mar 16, 2014 11:01 am
    Year: 09' 250x
    Elevation: 1400'
    Temperature Range: 60-90 deg F
    Smog (AIS): N/A (250r head), air box plugs(applied kit)
    Airbox Modified Top: partial top cut
    Air Filter: Twin air, stock cage.
    Pilot Jet: 45
    Main Jet: 168
    Needle: NCYS
    Needle Clip Position: 3th
    Fuel Screw Type: R-D flex jet
    AP Modified: no
    Leak Jet: 1 turn
    AP Cover: Boysen QS3
    Exhaust Type: FMF powerbomb head pipe, powercore 4 slip on
    Pink Wire Modified: No, Planning on putting it on a switch to try it.
    Head: 07' 250R head, Kw valve's done by CRFSonly.
    Cam: 08' 250R cam.
    Piston: Vertex 13.5:1
    I have tried a wide range of jet choices and so far this has been my best setup, good power down low and snap up top,great trail bike. looking to go for a big bore on my next piston, and a crfsonly port job, that should pull a bit more power down low and all around. I like a good bottom pull, and its nice to still have it up top too.
  • mattpmeyer
    by mattpmeyer » Wed Jan 14, 2015 1:25 pm
    Year: 2005
    Elevation: 1100
    Temperature Range: 30-105
    Smog (AIS): NA
    Backfire Screen: No
    Air Filter: twin air
    Pilot Jet: 45
    Main Jet: 165
    Needle: JD red
    Needle Clip Position: 5th
    Fuel Screw Type: crfs only
    Fuel Screw Setting: 2.25
    AP Modified: no
    Leak Jet: Stock
    AP Cover: Stock
    Exhaust Type: Jardine RT4 full
    Exhaust Modified:
    Pink Wire Modified: Yes
  • SuperGMC
    by SuperGMC » Mon Aug 08, 2016 6:13 pm
    Year: 2006
    Elevation: around 1400
    Temperature Range: -15F-100F
    Smog (AIS): Stock
    Airbox Modified Top: No
    Air Filter: Stock
    Pilot Jet: Stock
    Main Jet: 150
    Needle: Stock
    Needle Clip Position: Stock
    Fuel Screw Type: Stock
    Fuel Screw Setting: Turned out until it ran nicely
    AP Modified: No
    Leak Jet: Stock
    AP Cover: Stock
    Exhaust Type: Stock
    Exhaust Modified: Spark arrestor removed
    If it's worth doing, it's worth overdoing
  • polimorph
    by polimorph » Thu May 11, 2017 3:17 am
    CRF250X
    Year: 2004
    Elevation: 0 to 2000ft (0 - 600m)
    Temperature Range: 30 to 80F (0 - 30C)
    Smog (AIS): NA
    Airbox Modified Top: 4x4"
    Backfire Screen: on
    Air Filter: Hiflofiltro
    Pilot Jet: 40 (stock), with 42 would need FS @ 0.5 turns out which is wrong
    Main Jet: 152
    Needle: NCYS (CCC needle)
    Fuel Screw Type: noname adjustable (china)
    Fuel Screw Setting: 1.5 turns
    AP Modified: 8mm O-ring mod, squirt adjusted by screw at perfect timing
    Leak Jet: 70
    AP Cover: Stock
    Exhaust Type: Full Stock CRF250R 2005
    Exhaust Modified: NA
    I use 13/51 gearing with Rekluse clutch which in my humble opinion is the most fun giving addon this bike can get. For hillclimbs oriented pilot 12/51 gearing would work a bit better.
    I use my bike 80% in the woods: gnarly, tight, technical, hillclimbs.
    It starts cold or hot at first 2 sec push button, or first kick and runs really really good, of course with absolutely no bog.
    It's just perfect.
  • Mtngoat00
    by Mtngoat00 » Tue Jun 27, 2017 7:26 am
    Year: 2016
    Elevation: sea level to 1500
    Temperature Range: New England weather
    Smog (AIS): removed- Toykomods kit
    Airbox Modified Top: 6x6" cut out
    Airbox Modified Sides:no
    Backfire Screen:stock
    Pilot Jet:45
    Main Jet:140
    Needle:stock- only one position available
    Fuel Screw Type: Tusk
    Fuel Screw Setting:2 1/4 out
    AP Modified:no
    Leak Jet: stock
    AP Cover:stock
    Exhaust Type: Lexx MXe slip on
    Exhaust Modified:no
    Pink Wire Modified:no
