Hot Cam Stage 1 v Stage 2
    by [email protected] » Fri Sep 29, 2006 9:00 am
    They e-mailed me the same thing when I was trying to figure out where all my compression went !
    You can sure try it though. Doug
  • gprodick
    by gprodick » Fri Sep 29, 2006 10:19 am
    Well, I guess I'll get to the bottom of it, when I do the install. Considering your experiences, I will at least be prepared to go to plan B, if it turns out to not work at the stock setting.
    Thanks, again.
    CRF450X,RaceTech,Rekluse,Scotts Stab. & disc guard, Flatland rad guards,IMS 3.2, E-Line skid, No-Toil w/stock screen
    Stock pipe,Ride @ 5000'-10,000'
    Air box top & sides, JD 45 pj 160 main red needle-#4
    FS 1 1/2
    Other bike CR500
  • xman
    by xman » Fri Sep 29, 2006 10:24 am
    Make sure you have a shim kit handy. Unless you have a decent dealer around you.
    Could you repeat that? In English this time!
  • xman
    by xman » Mon Oct 02, 2006 6:41 am
    As promised, I checked the clearence on my decompressor this weekend. With the exhaust valve at a perfect .011, the decompressor is at .022 .
    Hope this helps you.
  • gprodick
    by gprodick » Mon Oct 02, 2006 7:42 am
    Thanks, Stuck In Vegas. That's right about the stock setting.
    FS 1 1/2
    Other bike CR500
  • xman
    by xman » Mon Oct 02, 2006 8:05 am
    gprodick wrote:Thanks, Stuck In Vegas. That's right about the stock setting.
    It's close, but you still want to do the whole back it out till the starter dosen't turn thing to make sure it's right.
    by [email protected] » Mon Oct 02, 2006 8:07 am
    Yes you do, because a little bit makes a differennce.
    If your bike doesn't want to start, and spins and spins a lot longer than what it did before the install, you'll know your compression is down. Doug
    by [email protected] » Tue Oct 03, 2006 3:53 pm
    Did you have to change a shim SIV ? I did not. Doug
  • xman
    by xman » Tue Oct 03, 2006 4:35 pm
    [email protected] wrote:Did you have to change a shim SIV ? I did not. Doug
    Only the exhaust, and they were only off a little. I'm just a little anal that way.
    by [email protected] » Tue Oct 03, 2006 5:25 pm
    Well now SIV you've got a lot of company here on that anal part ! :P Doug
    RottenRob
    by RottenRob » Tue Oct 03, 2006 5:33 pm
    [email protected] wrote:Well now SIV you've got a lot of company here on that anal part ! :P Doug
    Someone moderate him quick, this is getting disgusting :shock:
    Life's tough, but it is even tougher when you're stupid.
    by [email protected] » Wed Oct 04, 2006 5:44 am
    By the way. what's recommended is .025 in, SIV has .022 in, and when you feel the difference between those two clearances it's more signuficant than you might think.
    When you look at it you'll see that .022 would have the valve tighter against the intake than .025 would, and that's the reason we were so far down on compression at startup. Doug
  • Mikie1
    by Mikie1 » Wed Oct 04, 2006 5:58 am
    Actually, .025 clearance would have resulted in higher compression. At .025, The decompressor would lift the exhaust valve .003 LESS...
    At .022 the valve would be lifted more, opening slightly earlier in the power stroke, and closing slightly later in the exhaust stroke; resulting in LESS compression.
    Now I'm REALLY confused... :?
    BTW-- The clearance you're measuring is the distance between the valve and its opening mechanism when the valve is closed, not the tightness of the valve against the valve seat. That is determined by the stiffness and preload of the valve spring.
  • gprodick
    by gprodick » Wed Oct 04, 2006 8:00 am
    I suspect, and it has been my experience, that the gap for the decompressor does not have to be that exact. It will function well over a much wider range than either the exhaust or intake valve settings, which are infinitely more critical.
    If the decompressor gap were way too much, the poor little starter motor would probably have a hard time turning the engine over.
    On the low side, the decompressor seems to work fine. .022" is not enough to make a difference, in my opinion. While trying to remedy a starter motor problem, I ran mine well below .022" and had no problem. I've heard of others who tried .015" or below and it seemed to work.
    I'm not saying it should be set low. I'm just saying I don't think it has to be that exact. It should not effect how the motor runs once started, as it should be disengaged at that point.
    FS 1 1/2
    Other bike CR500
  • xman
    by xman » Wed Oct 04, 2006 8:10 am
    gprodick wrote:I suspect, and it has been my experience, that the gap for the decompressor does not have to be that exact. It will function well over a much wider range than either the exhaust or intake valve settings, which are infinitely more critical.
    Have you tried it with a Stage 1 or 2 yet? It seems to me that all this back and forth won't mean crap until you do. Otherwise, we could debate this until the end of time and still have two different opinions.
    Install your Hot Cam and then we can have a conversation built on actual experience and facts, not just theory and opinions.
    Oh, and have a nice day. 8)
