Jetting database for Honda CRF's
    In2deep
    by In2deep » Mon Oct 09, 2006 9:08 pm
    2006 CRF 450R
    JD jetting kit.
    Red needle, 6th position
    180 main
    Fuel screw 1 3/4 out.
    JUST AS DIRECTED
    It took me about 1.5 hours to do breathing slowly and deeply, taking my time to make sure I was doing what I was supposed to.
    Manual and JD instructions in hand.
    Buttoned it all up and ......... first kick ba ba ba ba ba ba! 8-)
    Cold this bike has always taken 3-4 kicks.
    It seemed to idle nicely. I can't wait to see how things go when I go out to ride!
    I will do the O ring install a bit later. The first portion of this went so well I thought I would quit while I was ahead and revisit the rest later.
  • xman
    by xman » Fri Oct 27, 2006 2:49 pm
    2005 CRF450X
    JD kit
    Red needle middle
    170 main
    48 pilot
    1 1/4 out f/s
    Boyesen AP cover
    Stage 2 Hot Cam
    Rocket exhaust full system
    13/49 gearing
    see garage for all other mods
    Could you repeat that? In English this time!
    rstappenbeck
    by rstappenbeck » Tue Jan 09, 2007 7:38 pm
    Here is mine.
    -Randall
    2006 CRF 250X
    White Bros. E2
    158 Main Jet
    42 Low Jet
    Air Box Opened
    JD Jet Kit
    Red Needle
    5th Clip Position
    Elevation 685 Ft. Above Sea Level
    Avg. Temps from 91(Summer) to 28(Winter) Degrees.
    KevinM
    by KevinM » Wed Jan 10, 2007 6:00 am
    And here's mine for my New Jersey based '05 250X
    '05 CRF-250X
    White Bros E2 Exhaust
    JD Jet Kit
    JD's Red Needle- 5th pos from top
    162 Main
    42 Pilot
    CRFsOnly Fuel Screw 1-7/8 turns out (2 turns in the winter)
    TwinAir PowerFlo Air Filter Kit
    Opened Airbox
    cut n pasted just in case I change my Sig.
    09 CRF 450R
    07 CRF 250R
    FS 2 trns
    05 CRF 250X
  • fatty432
    by fatty432 » Tue Jan 16, 2007 10:08 pm
    paul turner wrote:crf450x 2500'-9500' tested
    JD Red Needle 4th pos.
    170 Main
    45 Pilot {stock}
    XR's ONLY Fuel Screw @2.0 avg.
    BOYESEN APC {a must}{no adjustments to linkage}
    PINK Wire Mod
    AIRBOX Mod per Honda Wrench {emulates R box}
    NAPALM Filter Screw
    ENGINE ICE
    UNI Air Filters {backfire screen removed}
    APPLIED CC Breather kit
    W.B. SMOG BLOCK KIT {10ft. of crap in the trash}
    TWO BROTHERS M7 Slipon w/P1 Powertip{quietcore also}
    GPR V1
    PROTAPER crhi
    TRAIL TECH Computer
    TRAIL TECH Dashboard
    FLATLAND ODO Spacer
    ASV F1 Lever Set
    WORKS CONNECTION Skid Plate
    UNABIKER Radiator Guards
    ONE IND. Technoflex Gripper Seat
    CRF's Only Graffix
    CYCRA PRO BEND Composite Handguards
    SPIDER Grips {awesome}
    SEAL SAVERS
    MAXXIS IT {fr.&rr.}
    FASTWAY Case Saver
    MOOSE S.S. Footpegs
    IMS 3.2 Nat/Wt Fuel Tank w/ Red Billit Cap
    MOOSE Fender Tube Pak
    MSR Rear Fender Pak
    This is a great thread, Paul you are exactly where I need to be. I am going for your config with the jetting. We will see how it turns out, May need some help come monday.
    Thanks
    2005 CRF450X, A little more broke in now. Gettin ready for my first oil change.
  • GIGDOG13
    by GIGDOG13 » Thu Feb 22, 2007 4:02 am
    05 CRF450
    JD JET KIT
    180 MAIN
    STOCK PILOT JET
    RED NEEDLE 6TH POSITION
    QUICK SHOT PUMP COVER MSR FUEL SCREW 1 7/8 TURNS
    900 FT
    TWIN AIR POWER FLOW KIT
    WHITE BROTHERS E2 SLIP ON
    BanditX
    by BanditX » Mon Feb 26, 2007 5:37 pm
    06 CRF250R
    700ft elevation
    180 main
    40slow
    fuel screw 1 3/4 out
    Boyesen AP cover
    Twin-air open system
    Needle red 5th clip position
    No exhaust mods
    JD Jetting set up on the money. I am impressed.
    CRF250R-lil racers bike now
  • Trucker
    Jetting database for CRF's
    by Trucker » Thu Mar 22, 2007 6:40 am
    06 CRF 450x
    So. Cal.
    WB E2 slip on
    Boyesen Quick Shot w/ o-ring
    removed smog
    case vent
    opened up airbox
    twin air complete air filter system
    170 main
    48 pilot
    65 leak
    red needle 4th clip down fron top
    crf fuel screw 1 and 1/8 out
    Starts easy with smooth idle
    Hits hard w/no bog, plug is a nice shade of tan.
    Thanks goes out to JD, CRF's Only and you guys.
    You made it easy!
    by Skoot22 » Tue Jul 17, 2007 1:31 pm
    The Skoot22 and Bocephus450x $30 450X Jetting kit
    All the R&D is done
    Honda 16233-men-671 NCVS needle 3rd pos.
    170 main
    42 pilot
    Fuel Screw 2 turns out
    Elevation: 1500'-9500'
    Airbox opened up
    Backfire screen removed
    Baffle removed
    This is an awesome setup with great throttle response and makes the bike feel very smooth.
  • colbar
    by colbar » Fri Aug 03, 2007 1:44 pm
    :shock: its truly amazing that you can jet the bike
  • honda_rules_2005
    by honda_rules_2005 » Sun Aug 05, 2007 1:01 am
    07 CRF450X
    JD jetting Kit
    Pro cercuit T-4 exhaust system
    Fully opend air box with twin air filter
    Pink wire Mode
    168 main
    45 Pilot
    Jd Winter needle in the 2nd pos
    air-fuel 1 1/2 turns out.
    I have changed the jetting
    I now have
    170 main
    45 pilot
    Jd summer needle in the 6th pos from top
    air fuel at stock adg
    Now its a absolute blast!
    Last edited by honda_rules_2005 on Thu Aug 16, 2007 8:24 pm, edited 1 time in total.
    07 CRF450X
    Pro cercuit T-4 system.
    JD jetting kit,
    Hotcams stage 2 cam,
    CP 13:01 piston,
    Head modified with oversized Billet titanium CRN couted valves allround, ampco45 copper seats and guids with spring set.& also heavilly ported.
  • colbar
    by colbar » Mon Aug 06, 2007 7:18 am
    :shock:
    :D :D JD Red Needle 4th pos.
    170 Main {165 for 8000-9500'}
    45 Pilot {stock}
    O-Ring Mod to link :D
    PINK Wire Mod
    UNI Air Filters : :) {backfire screen removed} :D :D
    paul #1
  • honda_rules_2005
    by honda_rules_2005 » Thu Aug 16, 2007 8:26 pm
    does any one have a JD Jetting kit instructions printout for a 05 CRF450R?
    07 CRF450X
    JD jetting kit,
    CP 13:01 piston,
  • billk
    by billk » Tue Sep 04, 2007 12:56 pm
    Model: 2006 250X
    Settings for what altitude: 800 – 1,200 ft
    Ambient temperature: 85F – 96F (low humidity)
    Main jet size: 155
    Needle used: NCYQ (Honda part 16202-MEN-671)
    Clip location: 4th (middle).
    Airbox mods: 3” square; cut open between three vertical ribs with rubber cover removed
    Air Filter changes: Moose
    Any other related changes:
    Leak jet: 55 (Honda part 99108-MEB-0550)
    Pilot jet: 45
    Fuel screw: 1/2 out (see note below)
    Exhaust: stock with baffle removed
    Accel. pump cover changed to Factory R&D
    (which included a easy-adjust fuel screw)
    No accel. pump linkage modifications
    Air pump and emission controls are stock (not blocked)
    Pink wire stock
    Gearing is stock
    Pump gas: Premium
    I tried a 42 pilot but had to open the fuel screw 3-1/4
    turns. With a 45 pilot, there is no bog and I can richen
    the mixture as weather gets colder.
    A 158 main jet worked, but the 155 seemed a bit better
    under the current weather conditions.
    I tried a 162, but it didn't feel as snappy as with the smaller mains.
    The engine now lugs very low and has good acceleration
    without bogging. There is an occasional backfire on downhill sections.
    I replaced the Phillips head screws on the float bowl with Allen head screws. This enables me to remove the bowl to access pilot jet, but it's still an hour-long job.
    Another observation: Jetting seemed to make a more noticeable improvement than upgrading the accel. pump cover.
    by Skoot22 » Thu Sep 13, 2007 8:48 pm
    billk wrote:Model: 2006 250X
    Main jet size: 155
    Pilot jet: 45
    Pink wire stock
    Gearing is stock
    Pump gas: Premium
    You can get to the pilot and main jet by removing the float bowl drain bolt, i believe it's a 17mm. Loosen the 2 hose clamps on each side of the carb and rotate the bottom toward you. You can get i believe the 6mm nut driver in there to get the main out and the pilot is right next to it. Should be like a 10-15 min job tops.
