450x jetting mystery still unsolved
    by crfsonly » Mon Jan 07, 2013 10:34 am
    i've seen similar symptoms with worn floating valve plates. check these as well.
  • slicnic
    by slicnic » Mon Jan 07, 2013 1:19 pm
    well the floating valve plate and seal are new just replaced them a few weeks ago , the needle looked fine but maybe il try put the stock honda one back in to see the difference ,when i had the carb out yesterday i blew out and cleaned every possible orifice so cant be blocked anywhere
    by crfsonly » Mon Jan 07, 2013 1:24 pm
    did you originally have an accelerator pump diaphragm that started to deteriorate?
  • slicnic
    by slicnic » Mon Jan 07, 2013 1:27 pm
    ive replaced that too the old one looked ok but still put in a new one and when i had the carb out i checked that and it makes a good squirt too so cant be that
    by crfsonly » Mon Jan 07, 2013 1:31 pm
    any chance you don't actually have the JD Kit for your CRF model?
  • slicnic
    by slicnic » Mon Jan 07, 2013 1:38 pm
    nah it has to be right cos when i first put it in years ago it went like a rocket and was 100% perfect, the bike is getting old now but iv replaced about every part possible
    by crfsonly » Mon Jan 07, 2013 1:42 pm
    hot start nut and plunger are in good condition and working correctly?
  • slicnic
    by slicnic » Mon Jan 07, 2013 1:48 pm
    yep that was all good returns back in wen u let go of it
    travisgio
    by travisgio » Thu Feb 07, 2013 12:33 pm
    I just solved a problem like this! Thought it was carburetion but it was my "stick coil" for $54 it's worth a shot.
    '07 250X
    A250
    D36#190G
    707Suspension.com
    SRT Offroad
  • slicnic
    by slicnic » Fri Jul 05, 2013 2:50 pm
    Ok well I found the solution to that problem the needle although it looked fine must of been slightly worn cos I put the old stock needle back in n instantly it was running better n the splutter is gone , so now I've bit the bullet n bought a brand new jd kit with new red needle n jets n I've set it up like it says n all seems good so il see how it goes thanks for everyone's help , I think I'm learning now not to be a tight arse and to just replace parts when they start to wear lol
    by crfsonly » Mon Jul 08, 2013 12:09 pm
    glad to hear the mystery is solved!
    crazybrother
    by crazybrother » Mon Jul 08, 2013 2:48 pm
    slicnic wrote:Ok well I found the solution to that problem the needle although it looked fine must of been slightly worn cos I put the old stock needle back in n instantly it was running better n the splutter is gone , so now I've bit the bullet n bought a brand new jd kit with new red needle n jets n I've set it up like it says n all seems good so il see how it goes thanks for everyone's help , I think I'm learning now not to be a tight arse and to just replace parts when they start to wear lol
    Hey contact JD and let them know what happened and they will help you out...
    I had a friend that had a problem with his Red Needle and they replaced it free of charge.
    2009 Honda 450x (Plated)
    2010 Honda VFR 1200
    2008 Honda CBR 600RR (Wifes)
    by crfsonly » Tue Jul 09, 2013 8:40 am
    that's a good suggestion. i'm confident they will replace that needle for you.
