250x stall and wont start when hot
  • lestruites
    Re: 250x stall and wont start when hot
    by lestruites » Fri Sep 07, 2018 4:40 pm
    almost done putting everything together but ... what is the secret to put the air box boot to the carb ... been playing with it for hours without success
    thank
    by JimDirt » Fri Sep 07, 2018 5:43 pm
    Don't install the bottom subframe bolts till you get the boot on , just the single top bolt , then i use a long skinny flat blade screwdriver to go between the boot and the carb inlet , and "work" the boot around , once you see its seated on the ignition side , then take a flashlight and flip out the kickstart so you can see on that side , if its all completely on , then tighten the clamp and install the lower subframe bolts , its kind of a pain , but once you do it a few times , it gets much easier
