Crf450 starting problem
    by JimDirt » Mon Dec 02, 2013 8:19 am
    Oops , i edited again while you were posting , check the jetting guidline i added on my prior post
    And thats great that you found someone to check it over , maybe with any luck he will have the jet you need or the tool to clean your current one
  • Pnut450f
    by Pnut450f » Thu Dec 05, 2013 9:06 am
    New spark plug in. Put tank back on got on 2nd kick fired no problem. Put the seat on bolted it up properly took it out and could not get it to start my leg is killing me once more. Striped it down again right down to check valves this time. Front 2 .0015/.038
    Rear ones about the same.
  • Pnut450f
    by Pnut450f » Thu Dec 05, 2013 12:43 pm
    Took carb apart to clean jets they were pretty clean main jet had numbers 168 on it. And the fuel screw has been tampperd with a fair bit
