Rekluse EXP 2.0 In Stock
    by [email protected] » Fri Jun 22, 2012 6:44 pm
    I know this post is a little old Weave, but if you've figured out/solved the 'whirring' sound could you post what it was ? If not I'd call Rekluse on it, after being sure I wasn't hearing a driveline hassle or maybe a wheel bearing.They are in my experience very good on the phone .
    Also, let's hear about that 280 kit. I have a 250X and am thinking of going that way when it's piston time. Thank you ! Doug
    Riley
    by Riley » Tue Sep 04, 2012 3:36 pm
    I really enjoy mine! So much so, I've thought about getting the upgrade kit to the full Core setup. I'm trying to find a price to do so.
    I do so much better in the rocks and nasties with it. I'm playing with the spring weights for engagement. Tried medium and heavy and I think I like medium better and may try the light on my 250x.
    Riley
    by Riley » Tue Sep 04, 2012 3:40 pm
    Rekluse doesn't recommend the EXP 2.0 for use with big bore kits or snow bikes.
    by crfsonly » Tue Sep 04, 2012 11:16 pm
    Correct. For big bore kit bikes they recommend the z-Start Pro.
    Ken
  • SMD
    by SMD » Tue Nov 06, 2012 7:21 am
    Hi, Just put the EXP 2.0 on my 08 450X. I love the way it works, but cannot live with the rattle it makes sometimes when you take off. I'm using the Honda red trans oil right now. I called Rekluse and they recommended that I replace my clutch basket with one of theirs. Has anyone found a solution better than replacing my clutch basket?
    by crfsonly » Tue Nov 06, 2012 1:33 pm
    give it some more break-in time and it may improve. what condition is your basket in? is it notched at all? how about the plates? in spec?
  • SMD
    by SMD » Wed Nov 07, 2012 3:50 pm
    Only 15 hours on the bike, so the basket, plates are in very good condition.
  • gripnrip
    by gripnrip » Mon Dec 10, 2012 2:40 pm
    I have a ? and hope someone may answer. My buddie just got a 07 x after riding mine he had to have it. Anyway the 07 came with a exp and the guy had it at max adjustment on the cable and perch. Actually the guy messed up the threads on the perch.I think the previous owner put the friction disks in the wrong order. There are 2 friction disks that are different then the others. Should i leave them out and use all the same ones? According to the service manual the first disk in and the last disk are different then the others.
    Thanks in advance. Joe
    ps this will be my 3rd rekluse i installed this month (2 drz400s) and mine will be here friday. awesome product.
    oldmxer95
    by oldmxer95 » Mon Dec 10, 2012 4:27 pm
    Another very satisfied EXP owner here. I have had one in my 2012 X for nearly a year. This one is my 3rd bike with a Rekluse. Won't own another one without it.
    Oldmxer95
    2012 CRF450X
    by crfsonly » Mon Dec 10, 2012 4:32 pm
    oldmxer95 wrote:Another very satisfied EXP owner here. I have had one in my 2012 X for nearly a year. This one is my 3rd bike with a Rekluse. Won't own another one without it.
    great review! yes, this is typical of most Rekluse owners i know.
  • mccraw5
    by mccraw5 » Fri Jan 04, 2013 4:30 pm
    Basically the Rekluse makes it easier to go slower and chug through very technical and rocky sections of trail correct?
    by crfsonly » Fri Jan 04, 2013 4:33 pm
    mccraw5 wrote:Basically the Rekluse makes it easier to go slower and chug through very technical and rocky sections of trail correct?
    it allows you to forget about having to slip the clutch when needed or pull the clutch in when you come to a sudden, unexpected stop, which would normally stall your motor. so, the nastier the trail trash the more the rekluse shines.
    Krannie
    by Krannie » Mon Jan 07, 2013 6:44 pm
    Actually, no.
    The Rekluse has a certain rpm where the clutch is fully engaged. Below that rpm, it is slipping. So, if you short-shift the 'chug'through nasty terrain, the clutch can slip. I found I had to ride in a higher rpm if going up long steep hills, or the clutch would get hot. That was the main reason why I took mine off; you can't easily shift up under full load, without the clutch slipping. It's supposed to slip, but it means you can't ride in the rpm you want, but only the rpm's above the engagement point.
    by crfsonly » Mon Jan 07, 2013 7:33 pm
    as an auto clutch it definitely won't auto select the correct gear. it will slip the clutch, just as you would have to do or stall the bike, if you are not in the correct gear. the engagement functions like a manual clutch, it's not an all or nothing engagement. the full engagement does not require a high rpm but yes, it will require a bit higher rpm than a manual clutch chugging just above the stall point. you're one of the very few i've heard of who felt this wasn't worth the auto clutch benefits. the good news for those considering a Rekluse is they offer a no questions asked return policy so you can try it and if you aren't convinced it's a keeper send it back.
    terb
    by terb » Mon Jan 07, 2013 9:02 pm
    I find I can ride at a low rpm going up long steep hills and my clutch does not get hot. And thats in second gear really lugging it. I love my Z Start Pro!! I also have a 14T on the front with a 51T on the rear.
    2012 450X
