front forks on crf230
  • chillyengineer
    by chillyengineer » Sat Nov 07, 2009 12:37 am
    Thanks for the very informative reply ,i got some cr125 forks /clamps/front wheel etc but they were that poor i havent gone with it ,im sooo pissed with the seller ive stalled on this for now :evil:
  • Crfanatic230
    by Crfanatic230 » Wed Dec 02, 2009 10:49 pm
    chillyengineer wrote:CR85 dont sound as beef as the CR125 forks ,has anyone bothered to swap out the rear shock for a cr item or similar anyone got any measurments for me to take to the breakers?? come on all you guys that have done this
    We did a CR85 conversion on our CRF230 and they were awesome. Plenty heavy duty enough. You'll need to change springs to .44kg/mm to account for the difference in weight of the bike.
    They are 37mm inverted Showas and they made a world of difference.
    how hard is it to change the springs out and all? i need to do this.
  • Rancher1977
    by Rancher1977 » Thu Dec 03, 2009 4:04 pm
    Just changing the springs out of the factory fork tubes is very easy, just get the front wheel off the ground, remove the hex caps on top of the forks and then remove the springs.
    2003 CRF230F
  • kurtgray
    by kurtgray » Sun Feb 28, 2010 6:41 pm
    Is there anyway I could buy the already modified triple clamp from you for the conversion to the cr125 forks for the crf230f?
  • chillyengineer
    by chillyengineer » Mon Mar 01, 2010 9:06 am
    sorry i have sold the lot,£200 :cry:are you in UK??
  • old hellraiser
    by old hellraiser » Fri Mar 05, 2010 3:50 pm
    I put a set of xr 250 forks on my 230. works real well
    2004 crf 230f , works performance rear and xr 250 forks, K&N filter,snorkel removed, procircuit T-4 pipe and header, rev box, bark busters, light kit,xr 250 carb, 14/48 gearing BBR 240 bigbore
  • Tanner22
    by Tanner22 » Sun Mar 07, 2010 8:06 am
    what mods were required for the XR250 forks?
    I just bent my front forks so now i'm in the market for either new 230 forks or i'm going the USD mod route. I can't decide. It doesn't seem to be any cheaper to buy used 230 forks than it does to upgrade to a USD mod.
  • old hellraiser
    forks
    by old hellraiser » Sun Mar 07, 2010 10:21 am
    I bought mine off ebay. all I had to do is bolt them on. IM Kayno he did a cr 125 conversion on the 230. sorry I can`t help you.
  • mdtoney
    by mdtoney » Tue Apr 20, 2010 3:00 pm
    I'm getting ready to do this same mod and I'm curious what the rider's weight is for your bike. The main rider of this bike will be about 145lbs, but I'm around 195 and will also ride it from time to time. Are the CR85 forks with .44kg/mm springs for a lighter rider, or will I be ok if I don't hammer it too hard?
    Thanks,
    Mike
  • silstarnz
    by silstarnz » Tue Sep 13, 2011 10:03 pm
    Thanks,
    Mike
    I weight about the same amount too I was told by honda that they can get .46 springs but thats as heavy as they would recomend going too although they did mention no one in New Zealand has done this conversion yet that they are aware of.
    I am super amped to give it a go
  • silstarnz
    Do the
    by silstarnz » Fri Sep 16, 2011 11:25 pm
    As per below link:
    http://www.thumpertalk.com/forum/archiv ... 93081.html
    it indicates that I need to have the left bottom fork send off to be modified?
    Do I need to do this? what is this needed for?
    QUOTE:
    "Send them the bottom clamp for modification 60.00 and the left fork 40.00"
  • mdtoney
    by mdtoney » Sat Sep 17, 2011 9:15 am
    The Reger brake adapter moves your brake caliper out - the 230 wheel and brake rotor are larger diameter than the CR80/85 parts - the caliper mount holes on the CR fork leg need different size threads. If you send your fork to Reger they will drill the caliper mount holes and tap new threads. I had a tap so I did it myself in my garage.
    When the brake caliper is relocated, your 230 brake line will be a little too short. I got a CR125 brake line off ebay for a few $$.
    Here's a few pics of my wife's bike with the Reger/CR85 parts:
    The Teardown
    New and old
    We ride in the woods so I put a headlight on for her. After she scratches up the front fender some more, I'll replace it with a 150R fender.
    by Old Dude » Wed Sep 21, 2011 10:34 pm
    I went to my local auto parts store and purchased the proper Heli-coil, drilled out the hole and installed it myself. Cost was about $16.00.
  • silstarnz
    by silstarnz » Fri Sep 23, 2011 12:36 pm
    Wow nice Job :D
    I really want to do this too
    can you please advise what you had to buy from reger?
    did you use one of there lower tripple clamps?
    where did you get your top tripple clamp?
    did you order your springs from them?
    did you keep you key switch or remount it?
    did you buy the 85/80 axle and use there adapter?
    are the forks length the same? or does the bikes front pitch change because the forks are shorter?
    Whats the best way to get hold of reger as I have just tried to call them and didnt get through I dont think leaving a voice message from NZ I will get a call back.
    I really appreciate your time.
  • silstarnz
    by silstarnz » Fri Sep 23, 2011 12:42 pm
    Did you get Reger to modify your lower tripple clamp?
    what bearing did you use? bearings for a CR85 stem?
