Crank rebuild part 2 FINALLY!
  • cruisers450
    by cruisers450 » Sat Aug 13, 2011 8:21 pm
    is the primary gear and such all tightened up as well? it takes up the slack.
  • lick1000
    by lick1000 » Sun Aug 14, 2011 11:07 am
    No, I do not have any gears connected to the crank yet.
  • lick1000
    by lick1000 » Fri Aug 19, 2011 3:42 pm
    As you said once the gears were on all the slack went away. Thanks
  • culprit1384
    by culprit1384 » Fri Oct 07, 2011 12:33 pm
    I know this is old, but inst the main crank bearing in backwards? Shouldn't the beveled edge be up so that the bearing braces are bolted on over the bearing?
    euromike_85
    by euromike_85 » Fri Oct 14, 2011 2:58 pm
    culprit1384 wrote:I know this is old, but inst the main crank bearing in backwards? Shouldn't the beveled edge be up so that the bearing braces are bolted on over the bearing?
    Very good observation! i installed the main bearing backwards and had to reheat and take them out again to turn em around, i tried to explain it in words after on the post (the bearing has a "cut-away" along one edge which when installed should face toward the inside of the engine so that the locking tabs fit!, but didnt want to make the post confusing. i appologize for this and the pics
    2004 CRF250R
  • culprit1384
    by culprit1384 » Mon Nov 07, 2011 4:01 pm
    HAHA... No worries.. I just used your whole thread to successfully rebuild my 05' Crf250. I had the hardest time finding out which way that main bearing went in and finally i just went on ebay and looked at people selling the case to see what factory way it was in.. Great Thread
  • 450xaussiethunder
    by 450xaussiethunder » Thu Jul 14, 2016 6:07 am
    Hi I removed my stator cover on my 450x and there is a seal with a spring on my flywheel shaft in front of the flywheel nut... would this be the oil seal from inside the stator cover itself ?
    If so it seems worn out and I can not find any close up pics to see if the seal is the same as the 1 on my shaft
  • 450xaussiethunder
    by 450xaussiethunder » Sun Jul 17, 2016 5:07 pm
    It was my stator seal I figured it out
    Can you replace the left crankshaft seal without splitting the motor?
