04 crf450 wrote:no, after you drain your radiator fill it up with water and then drain it out and then fill it with engine ice. i was told to do this because engine ice and raditor fluid makes a gel (not good)
04 crf450 wrote:Has anyone used this, does it work. They claim that it can make your engine run up to 60 degrees cooler.
jt1872001 wrote:if you really want to lower engine temps add redline watter wetter to your coolant. it lowered the coolant temp in my off road car 5 degrees at idle.
in my bike and buggy i've been using toyoa supper long life coolant.it is pre mixed and comes in a 1 gallon jug. i think it is $25ish? but i get it for free (toyota tech).
my bike would boil over allot with the factory honda coolant and the radiator was always low.after the switch to supper long life it hasn't been low once= no boil over.
toyota created this coolant to be able to raise combustion temps reducing emisions.
it is very thin/watery and transfers heat more efficiantly than traditional coolant.
