Jetting Database
  • -Ghostface-
    by -Ghostface- » Tue Jun 24, 2008 6:04 pm
    Year:2007
    Elevation:0-2000ft
    Temperature Range:40-100F
    Airbox Modified Top:snorkel out
    Backfire Screen:stock
    Air Filter:Uni
    Pilot Jet:45
    Main Jet:132
    Needle:power up
    Needle Clip Position:middle (3rd)
    Fuel Screw Type:CRF's Only
    Fuel Screw Setting:1 1/2 turns out
    Exhaust Type:stock
    Exhaust Modified:baffle out
  • Rancher1977
    by Rancher1977 » Mon Jun 30, 2008 7:16 pm
    Year: 2003
    Elevation: 1200-2000 ft.
    Temperature Range: 30-96
    Airbox Modified Top: Snorkel & Grommet Removed
    Backfire Screen: Stock
    Air Filter: UNI
    Pilot Jet: #45
    Main Jet: #120
    Needle: Factory Needle
    Needle Clip Position: Middle (3rd Position)
    Fuel Screw Type: CRF's Only
    Fuel Screw Setting: 1 1/4 turns out
    Exhaust Type: Stock
    Exhaust Modified: Baffle Out
    2003 CRF230F
  • crf230rnb
    by crf230rnb » Thu Aug 28, 2008 3:04 pm
    Year: 2008
    Elevation: Virginia
    Temperature Range: 30-120
    Airbox Modified Top: yes/holes drilled/openSnorkel & Grommet Removed
    Backfire Screen: yes
    Air Filter: dual
    Pilot Jet: stock
    Main Jet: 132 998773-ghb-1320
    Needle: Honda Full Power Needle 16012-kps-921
    Needle Clip Position: 4
    Fuel Screw Type: stock
    Fuel Screw Setting: 2 turns
    Exhaust Type: bbr
    Exhaust Modified: bbr-d2
  • tomvcrc
    by tomvcrc » Thu Jan 15, 2009 4:42 pm
    Year: 2007 230f
    Elevation: 800ft
    Temperature Range: 45-90
    Airbox Modified Top: snorkel removed, (2) 2 inch holes
    Backfire Screen: in place
    Air Filter: Uni
    Pilot Jet: 48
    Main Jet: 132
    Needle: Power Up
    Needle Clip Position: third position
    Fuel Screw Setting: 1.5 turns out
    Exhaust Type: stock
    Exhaust Modified: baffle removed
    "Growing old is inevitable, growing up is optional." -tomvcrc
    zackn291
    by zackn291 » Thu Mar 05, 2009 1:52 pm
    Year: 2005 230f
    Elevation: 700-900ft
    Temperature Range: 50-95
    Air Filter: Uni
    Pilot Jet: 42
    Main Jet: 132
    Needle: Power Up
    Needle Clip Position: second position
    Exhaust Type: Pro Circut t-4
    Exhaust Modified: None
    Blade
    by Blade » Fri Dec 11, 2009 6:48 pm
    Year: 2003
    Elevation: 6000+
    Temperature Range: 32*F - 100*F
    Airbox Modified Top: Removed Snorkel
    Backfire Screen: In Place
    Air Filter: Twin Air
    Pilot Jet: Stock
    Main Jet: Stock
    Needle: Stock
    Needle Clip Position: Stock
    Exhaust Type: Stock
    Exhaust Modified: Baff Removed
    2003 CRF230F
    FMF Powercore 4 Muffler
    CRF's Only Fuel Screw
    Power-up Needle
    Uni Air Filter
    Flatland Skid Plate
    Dakar Baja Kit
    Acerbis Hand Guards
    Dirt Bike Gear Rear Fender Pack
    Maier Front Fork and Disk Guards
    Trail Tech Computer
    VortecCPI
    by VortecCPI » Mon Jan 18, 2010 12:07 pm
    Year: 2009
    Elevation: 750 ft above sea level
    Temperature Range: 40'F - 100'F
    Airbox Modified Top: Snorkle Removed
    Backfire Screen: Still In
    Air Filter: UNI
    Pilot Jet: 48
    Main Jet: 120
    Needle: 03-05 Needle
    Needle Clip Position: 4th
    Fuel Screw Type: 2005
    Fuel Screw Setting: 1.0 out
    Exhaust Type: Stock
    Exhaust Modified: Baffle Removed
    Tried a 45 pilot first and was still too lean (Popping on decel)
    Tried a 132 main first and was too rich on top (Flattened out)
    I am now using Mike Coe's dyno jetting recommendations and it is worlds better and as fast as my buddy's XR250! For those of you still running a 132 main, you're missing out on 1.8 HP, and that's about an 11% gain. Here is an excerpt from Mike's dyno work"
    "It was worth more than 1.5 HP!! With the 132 the A/F mixture was @ 11.0:1 and the power would level out at 16HP. After going down to a 125 and then the 120, the engine pulled cleanly all the way to the rev limiter and 17.83HP. This was on a bone stock 230 with "power-up" mods. I could have gone even leaner and picked up a little more power, but decided to stay a little conservative."
    The dirt dragstrip proved beyond any doubt this setup far outperforms the "Power-Up" setup.
  • crf230frider
    by crf230frider » Wed May 12, 2010 5:29 pm
    Year:
    Elevation: 1500 ft
    Temperature Range: -10/85
    Airbox Modified Top: snorkel off, uni air box vents
    Air Filter: k&n
    Pilot Jet: 48
    Main Jet: 135
    Needle: honda full power needle
    Needle Clip Position: 3rd(center)
    Fuel Screw Type: crfs only
    Fuel Screw Setting: 1 3/4 out
    Exhaust Type: pro circuit t-4 full system
    Exhaust Modified: no
    jeanradunz
    by jeanradunz » Sun Jun 27, 2010 7:25 pm
    Year: 2008
    Elevation: 343m
    Temperature Range: 10/40º Celsius
    Airbox Modified Top: snorkel off and cover air filter modification (need picture?)
    Air Filter: Twin-air dual stage
    Pilot Jet: 55
    Main Jet: 142
    Needle: Stock
    Needle Clip Position: 3rd (center)
    Fuel Screw Type: Anker
    Exhaust Type: BRC Big-Bore full system
    Exhaust Modified: BRC Power model
    At.
    Jean Radünz
    MSN: [email protected]
    [Off road since 1993: Honda CG125 79 > .... > Honda CRF230 08]
    27°37'33 South
    54°18'28" West
  • scotsy
    by scotsy » Tue Mar 29, 2011 10:55 am
    Year: 2005
    Elevation: 0-2000ft
    Temperature Range: 20f-80f
    Airbox Modified Top: SNORKEL OUT
    Backfire Screen: IN
    Air Filter: STD
    Pilot Jet: 45
    Main Jet: 120
    Needle: C30F POWER-UP
    Needle Clip Position: 4TH GROOVE
    Fuel Screw Type: STD
    Fuel Screw Setting: 2.5 TURNS
    Exhaust Type: STD
    Exhaust Modified: BAFFLE OUT
    Planning on installing 48 pilot and extended fuel screw to aid adjustment
  • scotsy
    by scotsy » Fri Apr 15, 2011 1:59 am
    EDIT: installed Kouba extended fuel screw and settled on 45 pilot jet
    Year: 2005
    Elevation: 0-2000ft
    Backfire Screen: IN
    Air Filter: STD
    Pilot Jet: 45
    Main Jet: 120
    Fuel Screw Type: Kouba extended
    Fuel Screw Setting: 2.0 TURNS out
    Exhaust Type: STD
  • JohnSBA
    by JohnSBA » Sun Jun 12, 2011 12:22 pm
    Year: 2006
    Elevation: 0 - 2000ft
    Temperature Range: 60 - 85 F
    Airbox Modified Top: remove snorkle
    Backfire Screen: stock
    Air Filter: Uni
    Pilot Jet: 45
    Main Jet: 120
    Needle: 03-05 Needle C39A
    Needle Clip Position: #4
    Fuel Screw Type: kouba
    Exhaust Type: stock
    Exhaust Modified: remove baffle
    This is the Mike Coe jetting setup. I've tried everything, I'm sold on this setup.
    2018 Yamaha YZF-R1
    2017 Ducati Multistrada 1200s
    2006 Honda CRF 250x (stolen)
  • MXer746
    by MXer746 » Fri Nov 25, 2011 11:48 pm
    Year: 2003
    Elevation: 815 FT above sea level
    Temperature Range: 50~90 deg F
    Airbox Modified Top: No
    Backfire Screen: Yes
    Air Filter: OEM Honda
    Pilot Jet: 42
    Main Jet: 102
    Needle: 39A
    Fuel Screw Type: OEM Honda
    Fuel Screw Setting: 2 turns out
    Exhaust Type: stock
    Exhaust Modified No
  • Harley
    by Harley » Fri Nov 02, 2012 7:43 am
    Year: 2004
    Elevation: 2500-7000ft.
    Temperature Range: 50-90 deg f
    Backfire Screen: removed
    Air Filter: stock
    Pilot Jet: 48
    Main Jet: 130 (exhaust turns red hot with a 120)
    Needle: 03-05 stock C39A
    Fuel Screw Type: crf fuel screw
    Exhaust Type: BBR D2
    Note: Bike starts and runs fantastic!! Still no comparison to CRF250X.
    MODS:
    BBR 240CC BIG BORE KIT (Definitely worth doing)
    BBR PERFORMANCE CAM & VALVE SPRINGS
    REV BOX
    BAJA DESIGNS LIGHTING KIT
    RICKEY STATOR (80w)
    Honda 1983 V-65 Magna
    Honda 2008 XR650L
    Honda 2000 CR500R
    Honda 2008 CRF250X
    Honda 2004 CRF230F
    Honda 2009 CRF450X
  • Sloloco
    by Sloloco » Mon Dec 31, 2012 7:50 pm
    Socrates wrote:Year: 2006
    Elevation: 900
    Temperature Range: 45 - 90
    Air Filter: Uni
    Pilot Jet: 45
    Main Jet: 132, Honda part # 99113-GHB-1320
    Needle: power up, Honda part #16012-KPS-921
    Needle Clip Position: middle
    Fuel Screw Type: Crf’s Only Fuel Screw
    Fuel Screw Setting: between 1 1/2 & 3/4 out
    Exhaust Type: T-4 Pro Circuit
    Thanks for the post Socrates! Living in the same town, and having like mods, I'm going to give your jetting configuration a shot on my '05.
    Cheers, Lance
