Index: Carb Jetting Database
    KevinM
    by KevinM » Fri Jun 15, 2007 1:06 pm
    Year: 2005
    Elevation: 100-400 MSL
    Temperature Range: 30-90 Deg F
    Smog (AIS): N/A
    Airbox Modified Top: yes
    Airbox Modified Sides: no
    Backfire Screen: TwinAir Power Flow Frame
    Air Filter: TwinAir
    Pilot Jet: 42
    Main Jet:162
    Needle: JD Red
    Needle Clip Position: 5th from top
    Fuel Screw Type: CRFsOnly
    Fuel Screw Setting: 2 turns out
    AP Modified: no
    Leak Jet: Stock
    AP Cover: Stock
    Exhaust Type: White Bros E2
    Exhaust Modified:
    Pink Wire Modified: no
    09 CRF 450R
    07 CRF 250R
    FS 2 trns
    05 CRF 250X
  • billk
    by billk » Tue Sep 04, 2007 5:23 pm
    Year: 2006
    Elevation: 800 – 1,200
    Temperature Range: 85F – 96F
    Smog (AIS): stock
    Airbox Modified Top: 3” square
    Airbox Modified Sides: No
    Backfire Screen: Stock
    Air Filter: Moose
    Pilot Jet: 45
    Main Jet: 155
    Needle: NCYQ (Honda part 16202-MEN-671)
    Needle Clip Position: 4th (middle)
    Fuel Screw Type: Factory R&D
    Fuel Screw Setting: ½ - 3/4
    AP Modified: No
    Leak Jet: 55 (Honda part 99108-MEB-0550)
    AP Cover: Factory R&D
    Exhaust Type: Stock
    Exhaust Modified: Baffle removed
    Pink Wire Modified: No
    Could go to 158 main.
    No bog.
  • racer105x
    by racer105x » Mon Sep 17, 2007 6:26 pm
    Year:2005
    Elevation:6500-9500
    Temperature Range:68 to 95
    Smog (AIS):N/A
    Airbox Modified Top:yes
    Airbox Modified Sides:no
    Backfire Screen:removed
    Air Filter:Uni
    Pilot Jet:42
    Main Jet:158
    Needle:JD
    Needle Clip Position:3rd from top
    Fuel Screw Type:MSR
    Fuel Screw Setting:2 1/4
    AP Modified:
    Leak Jet:stock
    AP Cover:
    Exhaust Type:FMF Powerbomb/Fmf Poewercore silencer
    Exhaust Modified:
    Pink Wire Modified:yes
  • redrooster65
    by redrooster65 » Sat Oct 27, 2007 12:35 pm
    It has always been fat, planning a Colorado trip so I leaned out the main while it was apart for the topend.
    Runs crisp with o bog.
    Year: 2004
    Elevation: 4,000 - 9,000
    Temperature Range: 50 - 100
    Smog (AIS): No
    Airbox Modified Top: Yes
    Backfire Screen: Yes
    Air Filter: Stock
    Pilot Jet: 42
    Main Jet: 155 now 150
    Needle: Red
    Fuel Screw Type: CRF's Only
    Fuel Screw Setting: 1 3/4 now 1 1/2
    AP Modified: No
    Leak Jet: 55
    AP Cover: No
    Exhaust Type: Stock
    Exhaust Modified: Drilled
    Pink Wire Modified: Yes
  • Toobie
    Re: HOW TO: CARB JETTING DATABASE
    by Toobie » Wed Nov 21, 2007 4:01 am
    [b]Year: 2005
    Elevation: 400'-1200'
    Temperature Range: 45-95 F
    Smog (AIS): N/A
    Airbox Modified Top: cut 3"x3"
    Backfire Screen: stock
    Air Filter: Ready Filter
    Pilot Jet: 42
    Main Jet: 155
    Needle: stock
    Fuel Screw Type: stock
    AP Modified: no
    Leak Jet: stock
    AP Cover: stock
    Exhaust Type: stock
    Exhaust Modified: drilled 3/4"
    '05 CRF250X
    Kibblewhite Stainless Intake Valves
    WC skidplate
    Acerbis Brush Handguards
    cut airbox/155main/42 pilot/clip on 4th pos.- hauls butt, no bog
    fuel screw 2 turns out
    900'MSL
    '05 CRF80F (son's)
    '06 KTM 105 SX (son's)
    CRF_Rod
    by CRF_Rod » Wed Jan 02, 2008 2:19 pm
    Year: 2006
    Elevation: 950'
    Temperature Range: Winter now 30-40
    Smog (AIS): N/A
    Airbox Modified Top: No
    Air Filter: Stock
    Pilot Jet: 42
    Main Jet: 152
    Needle: JD Red
    Fuel Screw Setting: 2 1/4
    AP Modified: JD kit large O-ring
    Leak Jet: Stock 55
    AP Cover: Stock
    Exhaust Type: Stock
    Exhaust Modified: No
    Bike runs perfect!
    06 CRF250X, 06 CR125, 08CRF230L
    BadCarma505
    by BadCarma505 » Sat Jan 12, 2008 8:12 pm
    Year: 2006
    Elevation: 10-100 feet
    Temperature Range: 60-100
    Smog (AIS): no
    Backfire Screen: yes
    Air Filter: stock
    Pilot Jet: 42
    Main Jet: 158
    Needle: JD red needle
    Fuel Screw Type: Stealth Racing
    Fuel Screw Setting: 1 1/4 turns out
    AP Modified: yes, small o-ring
    Leak Jet: stock
    AP Cover: stock
    Exhaust Type: stock
    Exhaust Modified: baffles & discs removed
  • gprove
    by gprove » Mon Mar 03, 2008 6:11 pm
    Year: 2006
    Elevation: 0-4000
    Temperature Range: 35-90
    Smog (AIS): stock
    Backfire Screen: no
    Air Filter: stock
    Pilot Jet: 42
    Main Jet: 158
    Needle: JD red
    Fuel Screw Type: CRFonly fuel Screw
    AP Modified: NO
    Leak Jet: stock
    AP Cover: no
    Exhaust Type: stock
    Exhaust Modified: no
    Pink Wire Modified:no
    JD kit RIPS!!!!
  • Motown250X
    by Motown250X » Sun Mar 09, 2008 7:32 pm
    Year: 2007
    Elevation: 0-3000
    Smog (AIS): Removed with XR's only block off
    Air Filter: Stock
    Pilot Jet: 42
    Main Jet: 160
    Needle: JD red
    Fuel Screw Type: JD
    Fuel Screw Setting: 1.5 turns out
    AP Modified: No
    Leak Jet: Stock
    AP Cover: Stock
    Exhaust Type: Stock header with 250R muffler
    Exhaust Modified: PMB sparky
    2007 CRF250X
    2008 CRF250R
    2011 CRF450R
  • jtmach1
    by jtmach1 » Wed Mar 26, 2008 12:03 pm
    Year: 2006
    Elevation: 0-3,000
    Temperature Range: 50-90
    Smog (AIS): stock
    Airbox Modified Sides: stock
    Air Filter: ready racing
    Pilot Jet: 45
    Main Jet: 165
    Needle Clip Position: 5th position
    Fuel Screw Type: Zip tye
    AP Modified: no
    Leak Jet: stock
    AP Cover: stock
    Exhaust Type: Full R exhaust
    Exhaust Modified:
    Cam: Hot Cam, Stage 1
    06 250x, air box, full R exhaust, 06 R cam, JD jet kit, red needle, AP mod, backfire screen, 165 main, 42 pilot
  • staticbags
    by staticbags » Sat Mar 29, 2008 6:33 pm
    Year: 2006
    Elevation: 50 - 3500
    Temperature Range: 50-100 deg.
    Smog (AIS): ? stock i guess its a tx bike
    Backfire Screen: NO
    Air Filter: stock
    Pilot Jet: stock (gonna change to 42)
    Main Jet: 165
    Needle: RED
    Fuel Screw Type: after market (it's red?)
    Fuel Screw Setting: 1.75 turns out
    AP Modified: ? stock i think
    Leak Jet: ?
    AP Cover: ?
    Exhaust Type: 250R with pro billet sparky
    Exhaust Modified: yes
    Pink Wire Modified:no (dont' think so)
  • z324u
    by z324u » Sun Apr 13, 2008 6:59 pm
    Year: 2006
    Elevation: 0-1000
    Smog (AIS): no smog
    Backfire Screen: removed
    Air Filter: stock
    Pilot Jet: 45
    Main Jet: 168
    Needle: RED
    Fuel Screw Type: zip ty
    AP Modified: no
    Leak Jet: stock
    AP Cover: stock
    Exhaust Type: stock
    Exhaust Modified: cut both discs off baffle
    nice tan brown plug. bike RIPS
    06'crf250x
    07'crf150f
    07'trx420 rancher
    07'crf70f
  • Addicted
    by Addicted » Sun Apr 13, 2008 8:42 pm
    Year: 2006
    Elevation: 600-900 ft
    Smog (AIS): N/A 49-state
    Airbox Modified Top: Yes (per Honda Wrench)
    Air Filter: Stock
    Pilot Jet: 42
    Main Jet:165
    Needle: JD Red
    Fuel Screw Setting: 1 3/4 turns out
    AP Modified: Thick band (JD kit)
    Leak Jet: Stock
    AP Cover: Stock
    Exhaust Type: Stock
    Exhaust Modified: Baffle drilled 11/16
    Pink Wire Modified: in place
    Riley
    by Riley » Sun Jun 15, 2008 4:46 pm
    Year: 2007
    Elevation: 4000-9000'
    Temperature Range: 50-100*
    Smog (AIS): Stock
    Airbox Modified Top: CCC Mod
    Backfire Screen: Removed
    Air Filter: Twin Air with No Toil oil
    Pilot Jet: 42 (stock)
    Main Jet: 165
    Needle: JD Red
    Needle Clip Position: 3rd
    Fuel Screw Type: R&D Flex Screw AWESOME!
    AP Modified: No
    Leak Jet: Stock
    AP Cover: Stock
    Exhaust Type: FMF Q4 Muffler
    NCFRC
    by NCFRC » Sun Jun 22, 2008 7:29 am
    Year:2004
    Elevation:0-2000
    Temperature Range:50-80
    Smog (AIS):NA
    Airbox Modified Top:Full Top
    Airbox Modified Sides:NO
    Backfire Screen:NO
    Air Filter:UNI
    Pilot Jet:45
    Main Jet:160
    Needle:stk
    Needle Clip Position:stk
    Fuel Screw Type:stk
    Fuel Screw Setting:2 out
    AP Modified:NA
    Leak Jet:55
    AP Cover:NA
    Exhaust Type:Full R Exhaust
    Exhaust Modified:Stk R
    Pink Wire Modified:Yes
    Factory Connection suspension , Trail Tech Tach, Final gearing 13 / 52 , Stk X cam
    Good usable power , Very Strong
