Help? 2017 Crf 250L Ebc Clutch replacement Removing judder spring
  • Scott9951
    by Scott9951 » Sun Dec 22, 2019 10:06 am
    I replace the clutch in my 2017 CRF 250 L with the EBC 1313 kit to remove the Judder spring. Installation seemed fine after everything is back together. The bike dies when I put it in gear put the clutch in??
    Re: Help? 2017 Crf 250L Ebc Clutch replacement Removing judder spring
    by JimDirt » Tue Dec 24, 2019 9:08 pm
    Question ???? , Did you re-adjust the cable and confirm that the clutch actuator is not over riding and re-engaging ??
    This is from the manual :
    Adjusting the Clutch Lever
    Freeplay
    # Minor Adjustment
    Attempt adjustment with the minor clutch
    cable adjuster first.
    1. Pull back the rubber dust cover.
    2. Loosen the minor lock nut.
    3. Turn the minor clutch cable adjuster until
    the freeplay is 0.4 - 0.8 in (10 - 20 mm).
    4. Tighten the minor lock nut and check the
    freeplay again.
    5. Install the rubber dust cover.
    # Major Adjustment
    If the minor clutch cable adjuster is threaded
    out near its limit, or the correct freeplay
    cannot be obtained, attempt adjustment with
    the major clutch cable adjuster.
    1. Pull back the rubber dust cover. Loosen
    the minor lock nut and turn the minor
    clutch cable adjuster all the way in (to
    provide maximum freeplay). Tighten the
    minor lock nut. Install the rubber dust
    cover.
    2. Loosen the major lock nut.
    3. Turn the major clutch cable adjuster until
    the clutch lever freeplay is 0.4 - 0.8 in (10
    - 20 mm).
    4. Tighten the major lock nut and check the
    clutch lever freeplay.
    5. Start the engine, pull the clutch lever in,
    and shift into gear. Make sure the engine
    does not stall and the motorcycle does
    not creep. Gradually release the clutch
    lever and open the throttle. Your
    motorcycle should move smoothly and
    accelerate gradually.
