Scotts Damper for Rally
  • dcoul1
    by dcoul1 » Wed Nov 27, 2019 9:24 am
    I see that the Scotts damper is not available for the Rally. Has anyone tried this? Seems like it should fit if the tank is not too close. I know the Rally tank capacity is a little more than the L version.
    Re: Scotts Damper for Rally
    by JimDirt » Fri Nov 29, 2019 12:19 pm
    What I would do is contact Scotts directly , as they are the ones that would make the mount for it , so maybe they can tell you if one is going to become available or not , I do not know if it would be practical , since the Rally is more Street than Off-Road , so not sure of the need of the dampener , since they are mainly used in "racing" situations , at least for the most part you kind of need to be riding hard to condone the use of one , so I would suspect that they did not see a market for it .... but I would guess if they get enough requests , or you asked them directly if they could do a 1 off , they would at least be able to give you realistic info as to whether it is feasible or not ..... :-k ;)
