Help, weak spark
  • Wracer
    Help, weak spark
    by Wracer » Tue Jan 15, 2019 1:29 pm
    i got a 2004 crf250x, and it has weak spark.
    This all started because the gauge display wasn’t lighting up. I unplugged the coil and ran power to the blue/yellow wire which also has the red wire for the display.
    Long and short of it is the bike has very weak spark now, won’t fire up
  • Wracer
    Re: Help, weak spark
    by Wracer » Tue Jan 15, 2019 2:55 pm
    So the bike seems to have spark.
    It’ll crank over, seems to fire, runs for a rotation or two then quits.
    Bike ran perfectly fine before I put power to the display red wire, which is also the black/yellow coil wire.
    by Aussiecrf230 » Tue Jan 15, 2019 7:30 pm
    How have you determined the spark is weak?
    Have you checked all the connections?
    If you can get it to fire and run only a short time it could be a fuel issue like a partially blocked pilot.
    Was it starting perfect just before you worked on the display or have you not run it for a while.
    The age of the fuel can also affect starting.
    Not saying it is not a spark problem, just I know starting issues can have many or multiple causes.
  • Wracer
    by Wracer » Tue Jan 15, 2019 7:47 pm
    It ran fine 5 minutes before I worked on it.
    I stated it, I notice the display/gauges wasn’t illuminating. So I ran 12v power to the black/yellow wire at the coil, which is where the display gets its power from. The coil was disconnected. I think I heard a snap. (Thinking electrical snap/short)
    I tried to start it, it usually starts right up.
    But this time it didn’t. I pulled the spark plug and the spark was so weak when cranking, I touched it, no shock. Kept cranking it, after 30 seconds got a shock.
    This is the wire I put 12v to.
    by Back2-2 » Wed Jan 16, 2019 6:13 am
    From what you just described - I suspect you fried your ignition module.
  • Wracer
    by Wracer » Wed Jan 16, 2019 8:14 am
    The computer?
    Can I put in one from a 2006 crf250r?
  • Wracer
    by Wracer » Wed Jan 16, 2019 8:16 am
    I have a 2006 crf250r computer, but it just has plugins.
    Mine has wires coming out of it, and plugins at the end of the wires?
  • Wracer
    by Wracer » Wed Jan 16, 2019 11:51 am
    I actually have a flywheel, magneto, cdi, and harness from a 2006 crf250r.
    Not sure if one part or all is interchangeable.
    I’d like to keep my lights, but I guess their not absolutely necessary
    by Back2-2 » Wed Jan 16, 2019 1:06 pm
    I would look for a used ignition module on ebay or Cl.
  • Wracer
    by Wracer » Wed Jan 16, 2019 5:33 pm
    Can’t find any on eBay
  • Wracer
    by Wracer » Wed Jan 16, 2019 5:57 pm
    This is the number on my cdi,
    071000-2530
    Now, will a crf250r cdi plug into my harness and work
    Or
    Would I be able to use a flywheel, stator, wire harness and cdi off of a 2006 crf250r?
    Any info appreciated.
    Thanks
  • Wracer
    by Wracer » Wed Jan 16, 2019 7:43 pm
    Anyone?
    by Aussiecrf230 » Wed Jan 16, 2019 10:20 pm
    I would suspect the 250x stator would have a charging or lamp coil that the 250r stator does not have. You would have to check the wiring diagram for both to be sure.
Users browsing this forum: Google [Bot] and 1 guest
