Pink Wire Mod
  • stub
    Pink Wire Mod
    by stub » Thu Oct 26, 2017 5:48 am
    HI, I have a 2010 CRF250X and I have read about the pink wire mod. But on my bike the pink wire seems to not go beyond the connector block, so cutting it would seem pointless. It comes in to the connector block as per the pics I have seen, but it connects to a blank/unused hole, so assuming cutting the wire will have no effect on my bike.
    Is this because it is newer model? I have only seen info on the pink wire cut for circa 2006/2007 models.
    Any help gratefully received. I am just looking for a bit more grunt out of it. Have done the air box cut out mod.
    Cheers
    Stub
    Re: Pink Wire Mod
    by crfsonly » Fri Oct 27, 2017 10:44 am
    Sounds like someone has already performed the Pink Wire Mod on your bike. Many cut it but we recommend moving it to an unused slot.
