This is a long post, so bear with me as I am not an engine expert!!!
I laid my bike on its side so I could adjust my Rekluse clutch 'installed gap' for the 2nd time that evening. As I was taking the clutch cover off, I noticed some fluid leaking from the largest diameter vent hose that sticks out under the bike.
Here is the sequence of events that led up to this.
1. I laid the bike on its side and adjusted the Rekluse installed gap the 1st time.
2. I put the clutch cover on and added 1000ml of tranny fluid to the tranny. 700ml is the normal amount, but I was told by Rekluse to use 1000ml because I have the oversize clutch cover.
3. I took the bike out for a quick 3-minute test ride. The installed gap must have been too big, as the clutch was slipping. So I took the big bike in the garage for 2nd adjustment.
4. I laid the bike on its side again, and saw about 300ml (rough estimate) leak out of that larger diameter hose!
I thought it was tranny fluid, and freaked out because I did not think that that hose connects to the transmission side. The fluid was rather dark, but I think it may have been tranny fluid that got dark from the friction plate particles as a result of the slipping clutch. Or maybe it was engine oil...sh*t, I dont know!
So I drained the tranny fluid and put it in a clear container. I also drained the engine oil and put it in a clear container. When I put them side-by-side, the engine oil was noticeably darker. This made me feel good, as I was worried that the tranny fluid may have entered the crankcase, but the different colors eased my concern.
But when I noticed that the large diameter hose connected to the side of the case on the other side of a gasket that the clutch was on, I got worried again.
So does anybody know if I actually got tranny fluid in the crancase, and mixed with the engine oil?
Thanks from a newbie dirt bike mechanic!
