Knowledge of hose
    NCLR1
    Knowledge of hose
    by NCLR1 » Tue May 29, 2007 12:28 pm
    OK, I did another valve check yesterday but I was rushing it. I need help identifying a hose that was connected to a clip that is attached to the breather hose. It's about 1/4 inch and is open on the end close to the breather. I just want to make sure that it doesn't connect to anything. Thanks
    Tony C
  • Ray
    by Ray » Tue May 29, 2007 2:55 pm
    The breather hose is connected to the valve cover. There is a smaller hose that is located above the breather hose and is supported by the breather hose with a plastic clip at the upper engine mount/bracket. The smaller tube remains open ended at the top.
    05 CRF250X
    03 CRF230
    03 XR80
    NCLR1
    by NCLR1 » Tue May 29, 2007 3:01 pm
    Thanks for the info. I thought that was right.
    Tony C
