by BigD » Sun May 06, 2007 10:05 am
I'm running the identical set up, and basically same elevation and temps. No problems......you can adjust to subtle elevation differences with the fuel screw, and keep the other main jet handy in case you really come down in elevation. The main jet is easy to change.
2006 CRF 250x
JD Jet, GPR Stabilizer, Bafflectomy, no backfire screen, 13/51 gearing, oil slick, smoke screen, heat seeking missles, twin 50 cal.'s, etc...
