ive just got rear wheel back after getting spoke work done and also a rear 53t talon sprocket -when i put the wheel back on it seems like it is a few mm off to the left and the sprocket is catching the chain guide on the left hand side and there is about 5 mm of space on the other side of the sprocket to the chain guide - ive had it on and off several times but to no avail-
the way ive assembled it is from the left -axel through chain block-swingarm-collar- wheel-collar-rear brakes -swingarm-chain block-washer -nut
although the chain guide has taken a knock or to in its time-it seems to even to be bent
ive also checked the rear brake is sitting in the groove on the swingarm
any ideas would be very helpful as im ment to be going riding in the morning
apologies for the essay but its hard to explain through a post
