CRF250X Tranny oil level.
  • gwht
    by gwht » Sun Apr 22, 2007 12:44 pm
    How much oil should be used in a 250X tranny. The 450X forum says to use a full quart in the 450X tranny. I did a search for the 250X and could not find anything. Thanks in advance.
    by Asmith » Sun Apr 22, 2007 4:58 pm
    670cc after draining is what Honda recommends.
    I run closer to 800cc.
  • gwht
    by gwht » Sun Apr 22, 2007 5:12 pm
    Is that for the same reason given for the 450x?
    by Asmith » Sun Apr 22, 2007 5:38 pm
    gwht wrote:Is that for the same reason given for the 450x?
    Yup. They are similar in design. Although the problem has turned up in the 450X, not the 250X, a little extra doesn't hurt anything.
    Monkeywrench
    by Monkeywrench » Sun Apr 22, 2007 6:47 pm
    I'm with Agent. Until recently, I'd been trying to stay as close to the recommended amount as possible (doing the side cover check-bolt removal, watching to make sure fluid just starts to come out). I think using more fluid than normal also helps lube the pressure plate throw-out bearing, which looks higher up in the center of the clutch than the recommended fill amount would contact.
    2006 450R
