How many of you are running a Big Bore Kit?
  • Andy Duffus
    by Andy Duffus » Sun Feb 25, 2007 5:27 pm
    Which one and what do you think?
    06' CRF 250x: Scotts w/BRP/Pastrana's, Fastway F3. JD Jet/Surge (165 M, 42 P, 50 L, Red 5th), 5:10 Case Saver, AR Vent, Twin Air, FMF Power Bomb, WB E2, Devol Eng. Suspension, WC Guards, Athena 280, KW valves and springs, 14/51 gear
  • ScottX
    by ScottX » Sun Feb 25, 2007 5:55 pm
    I have the athena 280 My bike rips now! It has more power at a lower rpm I can lift the front wheel without having to clutch it or down shift to get the bike to respond.
    The install was easy I had to remove some material from the outside of the cylinder skirt to get it to fit in the case but that was it. I also installed a 2007 R head with stainless valves and a hot cam.
