hard starting after mods
  • jerrypc69
    by jerrypc69 » Sun Feb 04, 2007 6:38 am
    I find my bike much more difficult to start when cold after the mods have been done
    choke is pulled and takes ages to start nearly flattening the battery temp here is 7c at the moment no problems at all before mods
    anybody got any ideas
    mods
    opened airbox
    158 main
    42 pilot
    4th clip
    2 turns on air screw
    by Asmith » Sun Feb 04, 2007 6:52 am
    Open up the fuel screw more. Try 1/8 of a turn at a time.
  • jerrypc69
    by jerrypc69 » Sun Feb 04, 2007 6:54 am
    thanks ~
    I will try that now
  • jerrypc69
    by jerrypc69 » Sun Feb 04, 2007 7:05 am
    2 1/2 turns and it starts a lot better
    but will try again in the next couple of days after it has been stood for a while
    this forum is the greatest \:D/
  • Halen
    by Halen » Sun Feb 04, 2007 7:51 am
    Are you running the stock needle?
    later... Van
    09 CRF 250R
    RMR lowered suspension
    Heavily armoured for the bush
    50 tooth rear
    soft gel seat
  • jerrypc69
    by jerrypc69 » Sun Feb 04, 2007 8:08 am
    yeh stock needle
    why ???
  • Halen
    by Halen » Sun Feb 04, 2007 8:13 am
    I first changed the jets without getting the JD needle and had a hell of a time. Went with the JD needle and a CRF/FS and it seemed to make all the difference in the world...
    Van
    09 CRF 250R
    50 tooth rear
    soft gel seat
  • jerrypc69
    by jerrypc69 » Sun Feb 04, 2007 8:21 am
    hmmm food for thought :-k
    by Asmith » Sun Feb 04, 2007 8:31 am
    I'm running the JD kit also and I couldn't agree more.
    It's the best $ 64.00 I've ever spent. That needle just makes the difference.
    And the CRF's Only fuel screw makes adjustments quick and easy.
  • Halen
    by Halen » Sun Feb 04, 2007 8:36 am
    It was a lot of your advise that sent me in that direction also. After spending hours upon hours trying to come up with a better solution I picked up kit from JD and never looked back... Well, I only looked back to see where my buds were. 8)
    thanks Agent
    later...
    Van
    09 CRF 250R
    50 tooth rear
    soft gel seat
  • jerrypc69
    by jerrypc69 » Sat Feb 10, 2007 4:54 am
    Tried to start it again today no go
    opened the fuel screw out 3 turns still nothing ](*,)
    ended up turning the fuel screw back to 2 turns and start it now by giving it a couple of twists with the throttle to pump some fuel through and she fires up no problem
    will the jd kit cure this problem :?:
    by JAWS » Sat Feb 10, 2007 6:44 am
    FWIW I give my throttle about three whacks to make starting easier when it is cold. That's not an uncommon issue. The JD kit has main jets and that special tapered needle, but that is all about mid to high speed. It doesn't help at the slow speed level, except for the 0-ring mod. That will give you a quicker shot of fuel when you whack the throttle. That's why it helps eliminate the throttle bog.
    If you continue to see issues, you might try stepping the pilot up one size to a 45. Be sure to re-work the fuel screw if you do that.
    by Asmith » Sat Feb 10, 2007 6:46 am
    I don't know if the JD kit will affect this issue. Doubt it.
    Its not so much a problem as it is a procedure.
    How we start our bikes.
    1) turn on fuel at petcock
    2) open choke
    3) twist throttle rapidly 3 times
    4) hit the happy button
    they start every time.
  • jerrypc69
    by jerrypc69 » Sat Feb 10, 2007 11:11 am
    yeh that works for me :)
    Just never had this sort of problem with my KTM but then is was a 525 so a big slug of piston going up and down may not be as critical with jetting
    you just pressed the button and held on ;) ;)
  • jerrypc69
    by jerrypc69 » Sun Feb 18, 2007 3:37 am
    Ok problem solved,
    pilot changed from 42 -45 starts on the button with no throttle
    happy days :lol: :lol: :lol: :lol: \:D/ :lol: :lol: :lol:
