Page 1 of 3
First ride on my 250x
Posted: Sun Jan 07, 2007 8:24 am
by jerrypc69
Just came back from my first ride on this bike .
All I can say is less is definitely more.
Laughed soo much at my buddys trying to keep up in the wet and muddy woods here in the UK on there 450's .
I think i'm going to like this bike
Posted: Sun Jan 07, 2007 8:44 am
Is it still stock, or have you done any mods yet?
Posted: Sun Jan 07, 2007 8:52 am
by jerrypc69
It's still stock thats what makes it even funnier.
Will be ordering some jets tomorrow and opening the airbox next weekend ,just wanted to ride it stock to see how much the mods would change it
Posted: Sun Jan 07, 2007 9:05 am
Your buddies aren't gonna want to ride with you anymore.
Especially once you open it up a bit...
Posted: Sun Jan 07, 2007 9:15 am
by jerrypc69
What would you advise on jetting
I am just going to open up the air box take the flametrap out and fit twin air filter.
I don't think need mess with the pink wire and dont want it any noisier.
Most riding done at 0-1000m above sea level
Posted: Sun Jan 07, 2007 9:20 am
jerrypc69 wrote:~
Do that and get the JD Kit. Makes things easy.
If you just want to do it on your own do this:
Change the needle to the 4th clip.(stock 2nd clip)
Change the main jet to a 158.(stock 130)
Change the pilot jet to a 42.(stock 40)
Open fuel screw to 2 turns from all in.
Makes the bike run way better, start easier and makes a bunch more power.
Posted: Sun Jan 07, 2007 9:22 am
by jerrypc69
Thanks
I will try that next week
Posted: Mon Jan 08, 2007 7:59 am
by KevinM
He ain't kidding Jerry. Those carb changes will make a big difference.
Starts much easier. 10-20 secs with the choke on, then idles almost like it had an EFI system.
I'm running larger main jet (162) because I have opened up the airbox and am running a White Bros E2 exhaust w/o the spark arrestor.
Posted: Mon Jan 08, 2007 10:45 am
by jerrypc69
Right jets ordered and on there way
purchased the filter today
time to get out in the garage and start stripping the crf
now where is that dremil
Posted: Mon Jan 08, 2007 11:21 am
by crf~rob
Gonna start work on mine today! Thanks to the help from ~ it should be a breeze. I plan on basically doing exactly the same mods as you....except i'm adding the smog block off kit also!
Happy riding
Posted: Thu Jan 11, 2007 11:41 am
by jerrypc69
I have been advised to do the AP mod do you think its worth it considering the rest of the mods I am going to do
Posted: Thu Jan 11, 2007 12:51 pm
jerrypc69 wrote:I have been advised to do the AP mod do you think its worth it considering the rest of the mods I am going to do
It's easier to do while you are in there. And its easy to just do the o-ring part (that's all most of us do).
I have the whole mod on PDF. PM me with your e-mail and i'll send it to you.
Posted: Thu Jan 11, 2007 2:59 pm
by jerrypc69
Thanks ~
will this do the same job as the boyesen accelerator pump cover
Posted: Thu Jan 11, 2007 3:04 pm
jerrypc69 wrote:Thanks ~
The AP mod will eliminate the off idle bog.
The Boyesen AP cover is designed to refill faster than the stock cover. The fuel supply for the AP is in the cover.
If you are constantly pumping the throttle, you can use up the fuel supply faster than the stock cover can refill and thus not get consistent shots of fuel.
The Boyesen cover is designed to fix that. I think only MX racers would ride in such a manner to
need the Boyesen.
Posted: Thu Jan 11, 2007 3:15 pm
by jerrypc69
Thanks again ~ your a wealth of information
I did a little searching on this site which has educated me lots on the subject
