Mount speedo sensor with Trailtech kit????
  • innovativemotorsports
    by innovativemotorsports » Tue Aug 10, 2010 9:54 am
    I'm running a 320mm front rotor and relocated caliper. Where is best to mount the speedo sensor wire on the fork? It looks like the fork guard would be easy and work well but I want to check first. For the magnet I'm running a magnet bolt that replaces one of the rotor bolts.
    Thanks!
  • jamminjimmi
    by jamminjimmi » Mon Aug 23, 2010 5:14 pm
    I just made a bracket out of some aluminum and put the proper bend in it and bolted it to the fork via the inner pinch bolt. Pretty easy
