no i didnt completely 100% clean the jets but i will thanks for the info brotherCheck the vent line coming from the gas cap , remove it and blow thru it , make sure it is clear , what you are describing seems like it is a lean condition ..... When you cleaned the carb did you actually remove the jets and flush them out ??? ... it only takes 1 spec of dirt to make the jet not flow correctly and cause a lean condition .
Copyright 2016-2017 © CRF's Only Forums. All Rights Reserved.
