150R in 150F Frame? Conversion question for Trike Build
  • JacobMonster
    by JacobMonster » Mon Sep 07, 2015 8:50 pm
    Hey guys!. Name's Jake. I own a 1984 Honda ATC 200X. Engine is toast, and I know for certain a CRF 150F/230F engine will bolt in the frame with no modifications. The reason I'm asking if the 150R has the same mounts has the 150F is because I would rather put a 150R engine in it. If Im right, the 150f has about 12HP, 230F is around 18HP give or take, and the 150R is 23Hp give or take. so if the 150R has the same mounts, then I can swap out the engines for better HP. Any info is much appreciated guys!
