talbzach wrote:I was having the same issue - huge bog right off idle. The AP nozzle was plugged. I did remove it by taking the carb apart and then turning the slot on the underside of the nozzle to "break" the press fit (mark the position of the slot with a Sharpie before turning for reassembly). I then pressed the nozzle with a flat screwdriver and it slid right out. Then I put the nozzle in a parts bath overnight. Reassembled and was like original - lots of snap of idle.
