Price check
    jww
    Price check
    by jww » Wed Sep 12, 2007 1:59 pm
    Would it be inappropriate to post specs of my bike in hopes of you guys helping me price it correctly?
  • loff
    by loff » Wed Sep 12, 2007 3:59 pm
    You would have a better response if you posted in the 450X board.
  • loff
    by loff » Wed Sep 12, 2007 5:59 pm
    I don't think that It would be inappropriate to ask that question.[/quote]
    jww
    by jww » Wed Sep 12, 2007 7:08 pm
    Thought about that but I figured a more local price would be better. Thanks though
    Dont really want to cross post now so I will go for it here.
    2006
    CRF450X
    40.9 hours total
    Oil & filter changed every 6-8 hours
    Air filter changed every ride
    Applied smog removal kit
    Applied vent kit
    CRF’s Only shark fin
    BRP fat bar mount
    Pro Taper CR Hi
    Cycra Stealth handguards
    Scott stabilizer tower and bar mount (no stabilizer)
    Brake Snake
    Cycra Stadium Plate
    Rear tugger
    Unabiker radiator guards
    Works Connection rear master cylinder guard
    Works Connection rear caliper guard
    Works Connection Skidplate
    Maxxis IT rear tire – 2nd tire ever on the bike
    DR. D hour meter
    Yuasa pigtail on battery
    White Bros E2 slip on
    JD jet kit
    Napalm air filter bolt
    STR fuel screw
    Twin Air power filter kit
    4 Twin Air filters (no-toil’d)
    Couple of spare bolts for oil filter cover and drain plugs
    All removed parts were kept
    Other mods
    Air box top and sides cut
    Odometer & headlight removed- 1 tab cut off upper and lower clamp cut down to better accommodate Cycra plate. Odometer and headlight can be reinstalled.
    Left side graphics are a little nicked from a knee brace I was wearing and one of the bolts are broken on the Cycra handguards. Other than that I think it’s a pretty clean bike. d
    jww
    by jww » Wed Sep 12, 2007 10:03 pm
    Thank you both
