CRF 250X QUESTIONS
  • FISHMAN
    CRF 250X QUESTIONS
    by FISHMAN » Wed Feb 27, 2008 8:23 pm
    My first question is will a 08 piston from a 250x fit into an 06 250 x
    Second question what is the difference between an r headgasket and a x headgasket or is there a difference .
    Thanks .
    by Asmith » Wed Feb 27, 2008 9:45 pm
    Question 1 - Yes.
    Question 2 - The stock '04 X head gasket measures .4 mm thick. (The '05 and '06 X gaskets are the same part number.)
    The '05 R head gasket measures .65 mm thick.
    (The '05-'07 R head gaskets are the same.)
    Using the Honda Service Manual compression ratio value of 12.9 : 1,
    the thicker gasket ('05 R) lowers the compression ratio to 12.3 : 1.
    If you want a higher compression ratio, use the '04 X head gasket.
  • 06CRF
    by 06CRF » Fri Oct 29, 2010 9:38 am
    where are you getting your parts from?, just trying to compare prices
