Locked 10 posts Page 1 of 1
Sprockets and chain modifications
    by crfsonly » Fri Feb 17, 2006 8:40 am
    Front and rear sprockets and chain selection discussion goes here.
  • Socal X Rider
    by Socal X Rider » Fri Feb 17, 2006 9:15 am
    Renthal Ultralight front (14T)
    DID gold T-Ring chain
    Ironman in the rear (48T in rear if front drive is left at 13T)
    AFAM would be my next choice.
    (Remember, wheel color choice comes into play with color on rear sprocket)
    02 RM250
    00 ZR-7
    by Smash » Fri Feb 17, 2006 11:53 am
    Not sure if this is the place. SFB makes a killer aluminum chain guide. TM Designworks has red plastic ones that look like they'd last longer.
  • whiteman
    by whiteman » Fri Feb 17, 2006 12:26 pm
    Second the iron man but would stay away from the light front. DID gold t-ring sounds good too.
    TM designs chain block is also a very good plus, with the ty davis quick release axle blocks.
    RottenRob
    by RottenRob » Fri Feb 17, 2006 1:08 pm
    May as well throw a Fastway Performance Billet Case Saver on for good measure :D
    Life's tough, but it is even tougher when you're stupid.
    uniped
    by uniped » Fri Feb 17, 2006 3:47 pm
    Sorry Ken this must be getting tough overlapping info-wise
    D.I.D. T-ring
    Black Renthal
    T.M. Design full kit
  • Showtime
    by Showtime » Sat Feb 18, 2006 1:36 pm
    What about sidewinder?? I have not heard much about them, but love the bling as far as the gold/black color combo.
    Cliff
    Rekluse w/perch adj
    BRP Triple Clamps 22m
    JD Kit
    Open Air Box
    Boysen Quickshot
    Acewell Speedometer
    TourTech GPS mount
    Scotts rear shark fin
    Works Connection skid plate, radiator braces.
    optaylor
    by optaylor » Sun Feb 19, 2006 5:50 am
    How bout the TriMetal Sprocket for the rear. Not only does it look good but it drops about a pound in weight.
    If all life is a stage, you would think someone would pick up the mic cords . They are a tripping hazard!
  • Rancha9
    by Rancha9 » Mon Feb 20, 2006 7:25 am
    I believe that this is one place where function should have preference over form... That said, I vote for the Ironman combo with the T-ring chain... The rear is still "blingy", I suppose you could anodize it if you wanted to, but with a bike that is supposed to run trails all day, every day, I think an aluminum rear would be too cheap.
    The stupid shall be punished, usually in a very grand way that will show up on the evening news...
    by Ernie Pezz » Mon Feb 20, 2006 5:54 pm
    Sidewinder with a gold T-ring chain! Oh yea, don't forget the Fastway case saver while were at it. Ernie
