Welcome to the site !!
Without hearing the actual noise , it is going to be hard to pinpoint what is going on ...... but .....If you look on the left side of the engine at the ignition cover , you will see a bolt at the bottom right corner that is larger than all the rest , right about at the tip of the shifter , this is the Engine oil drain bolt .... now if you look just behind it (basically look at the bolt by the shifter tip from down low) , and you will see another bolt back in there , THAT is the tranny drain bolt
Make sure none of the plates or disks are broken , and while the plates are all out , grab the clutch basket itself and see if it wobbles any , if it does , most likely the bearing is bad in the basket ....... Also make sure the basket is not worn , if it is worn it will have grooves like shown below , if it does , the basket is toast ..... this does not mean that is the source of your noise , since we can't hear it , there is no way to say for sure what the noise is , but either way , you will need to replace ALL the plates and disks .... maybe post a short video of the noise , and some pictures of the parts ....the more details , the easier it is to diagnose , you can order parts here , or anywhere online that ships to Canada , though the shipping time may be a bit , so if you can order local , it might be the quickest way to get the bike back up and running ....
Worn Basket
To post pictures you need a image hosting site like IMGUR , upload your pic to that , then copy the link for Forums/Message Boards and just paste that link into your post .... Videos you can just paste the link , or embed the video in the post by using the correct link for that ....
Weird , it is saying IMGUR Refused to Connect when you put the mouse over the picture .....
Did you use the link shown that I have circled in this picture ??
Can't find that link on my phone. Using Samsung internetWeird , it is saying IMGUR Refused to Connect when you put the mouse over the picture .....
