CRF100 crankshaft camchain gear
  • bruzer
    by bruzer » Tue Jun 09, 2020 2:14 pm
    Hello all, Im fitting a new camchain gear to crank and wondering how it is timed... Im thinking line a tooth up with keyway and press on there... Is this correct??? Can someone confirm this... Does anyone have a workshop manual on these...
    Re: CRF100 crankshaft camchain gear
    by JimDirt » Tue Jun 09, 2020 2:37 pm
    What year CRF100 is it ??
  • bruzer
    by bruzer » Tue Jun 09, 2020 10:00 pm
    Thanks Jimdirt... Looking forward to yarning to you guys .. Bike is a 2009
    by JimDirt » Wed Jun 10, 2020 12:07 am
    With the ignition cover off you should see some marks on the flywheel , the T mark should point straight up and align with the mark on the case , the cam sprocket should have a dot , it should face straight up as well , and the sprocket bolts should be level like this
    O O , I believe that engine has 2 timing chain tensioners , one near the bottom of the cylinder , at the rear on the left side , and one near the top of the head on the same side (ignition cover side) , the bottom is the main one for setting the basic tension and should automatically set once you loosen the adjuster bolt , then once the bike is running , if you hear any ticking , you adjust the top one on the head to fine tune it if needed .....
  • bruzer
    by bruzer » Wed Jun 10, 2020 12:14 am
    Yeah thanks jimdirt... but what I need to know is the crankshaft camchain gear... position to press on... will try upload photo in morning at workshop.. as this is all new to me this site...🤣🤣🤣
    by JimDirt » Wed Jun 10, 2020 12:20 am
    To post a picture you need a hosting site like IMGUR or something , you use the links for Forums or Message Boards , then copy that link and paste it into you post it will look like this [img]https:/ /i.imgur.com/LOQoe1O.jpg[/img]
    but show up like this
    by Aussiecrf230 » Wed Jun 10, 2020 2:11 am
    From memory with the little xr engines, with the lobes facing down the cog goes with O marking at the top.
  • bruzer
    by bruzer » Wed Jun 10, 2020 2:26 pm
    lets see if this works... these are the pictures of camchain gear that needs to be pressed on crank
    by JimDirt » Wed Jun 10, 2020 3:03 pm
    Yikes !!! , hopefully you have a replacement gear because that one is toast :shock: ....... but to answer your question , you align one of the teeth directly centered to the keyway
  • bruzer
    by bruzer » Wed Jun 10, 2020 3:23 pm
    Yep have one on its way... Thanks for confirmation Jimdirt.... Much appreciated...
    by Aussiecrf230 » Wed Jun 10, 2020 9:03 pm
    And I am guessing a new tensioner as well to stop it happening again.
    Have to be the worst sprocket I have seen.
  • bruzer
    by bruzer » Sun Jun 14, 2020 12:57 pm
    :lol: :lol: Yes new tensioner,valves,chain and sprockets...
  • bruzer
    by bruzer » Mon Jul 20, 2020 9:14 pm
    Afternoon
    Parts have arrived ready to assemble does anyone have torque settings for this ..
    Properly only need head nuts/rocker gear torque..
    But if someone as list would be great.. cheers guys
