Crf levers
  • Hammer
    Crf levers
    by Hammer » Sun Sep 15, 2019 7:48 pm
    Are all Crf 250 r and 450 levers the same
    If you can't ride good, then look good riding
    In the morning, we ride.
    2020 crf250r
    04 crf 250, power now, Icat, full fmf ti exhaust, hot cam. Tom Morgan ported head,New ti valves, springs.
    Re: Crf levers
    by JimDirt » Mon Sep 16, 2019 11:03 am
    No the perches varied for different years
    Clutch:
    07-12 CRF250 and 07-11 CRF450 are the same , 02-03 CRF450 different , 04-06 CRF250/450
    Brake:
    07-19 CRF250/450 are the same , 02-03 CRF450 is different from other years , 04-06 CRF250/450 the same
    Not sure on the clutch and the newest models .... :-k , I always struggle with that for my 02 450R , the 05-06 levers wont fit in the perch , its a different thickness at the mounting (04-06 levers are thicker where the bolt goes thru) , but if you use the perch for the same year levers they should work fine with no issues , as the only real difference is the thickness at the mounting point .... 8-[
    Re: Crf levers
    by Aussiecrf230 » Mon Sep 16, 2019 2:13 pm
    I have always thought there should be a worldwide standard for levers. Would make it so much easier when you bent or broke one. A bit like mobile phone chargers I guess until sanity reduces them to micro sd except for Apple.....
  • Hammer
    Re: Crf levers
    by Hammer » Mon Sep 23, 2019 4:15 pm
    Thanks I had the sunline max v1 s. One lever is broken. I thought I could get a red lever and reuse it..
    Really doesn't make sense to change them every other year. No real technology in levers.
    2020 crf250r
