Welcome to the site !!
What you would end up with is about the equivalent of maybe 1 tooth at the most i would guess , (larger) so it will up your ratio from a 3.462 , to maybe a 3.528 , so basically it would be like switching from 13/45 , to a 13/46 and i am not sure it would even do that , maybe more somewhere in between those numbers , if you could physically feel the difference , i would say it would be minimal , and you will only notice a very slight difference in top end gain , and a very slight loss of bottom end responsiveness , depending on the trails you ride , it might not be noticeable at all , and it should not dramatically affect your street performance if at all , maybe a few hundred RPM difference in top gear at most , i would think you would notice the stance difference when putting your feet down more than the difference in actual performance ...... at least that has been my experience with going to a larger diameter tire , i notice the stance and that is about the only difference i actually "feel" ....
