Please help> gaining oil in the engine
  • HONDA_20
    by HONDA_20 » Tue Jan 20, 2009 11:14 am
    I have a 2005 crf450r and i think my tranny oil is somehow leaking into my engine if this is even possible. I use the same oil on both sides but my tranny keeps going low and my engine is gaining oil and coming out my airbox. Please help me try to fix the problem...Thanks!
    motosicko
    by motosicko » Tue Jan 20, 2009 11:49 am
    There's most likely a right crank seal bad. Need to take right crankcase cover off, disassemble clutch to access seal. # 19 in drawing.Image
    Good news is you don't need to split cases. :)
  • HONDA_20
    by HONDA_20 » Tue Jan 20, 2009 7:44 pm
    thanks brotha man
  • lvanduyn
    by lvanduyn » Mon Feb 23, 2009 6:43 pm
    Does anyone know if the CRF 250r's have this same exact problem? Is the fix the same? My 250 also seems to be gaining oil on the motor side and losing some on the tranny side.
    amaviper
    by amaviper » Mon Feb 23, 2009 6:56 pm
    Looks like it. Check the parts fiche. Crankcase section.
    http://www.cyclepartsnation.com/pages/parts/viewbybrand/7/Honda.aspx
  • kayesport
    by kayesport » Wed Jul 08, 2009 1:35 am
    I forgot to reply to this after I finish the work
    Yes I replace the seal in between the engine and the gearbox and the problem disappeared
    20 minute job no problem at all
    Thanks for the help everybody on this one
    Richard Kaye
