Has anyone else had problems with there trail tech computer?
  • BillB
    by BillB » Sun Mar 18, 2007 5:42 pm
    For the second time the cable on mine has gone bad. There is no external damage to it, the magnetic bolt is still in place, wires look good but its not picking up anything. Anyone else had this problem?
    06 CRF 250X
    JD Jetting Kit
    Quick shot APC
    Air Box Mod
    White Bro E2 W R Header
    Works Skid Plate & Engine Guards
    Trial Tech Computer
    Smog block off kit
    Scotts Stabilizer
    Pro Tapers
    AVS F3 Levers
    S1 Hot Cam
  • Reddog88
    by Reddog88 » Mon Mar 19, 2007 10:51 am
    The only problem I've had with my lynx is the thing picking up the speed inconsistantly, like 20, 40, 10, 150...etc. Acording to it my max speed has been well over 300MPH!!!!!!! lol
    NCLR1
    by NCLR1 » Tue Mar 20, 2007 1:44 pm
    Reddog88 wrote:The only problem I've had with my lynx is the thing picking up the speed inconsistantly, like 20, 40, 10, 150...etc. Acording to it my max speed has been well over 300MPH!!!!!!! lol
    Did you mount your cable in the recommended position? I know some other people that didn't want to drill a hole in the caliper so they came up with some other way of doing it and it didn't work very well.
    Tony C
  • Reddog88
    by Reddog88 » Wed Mar 21, 2007 6:58 am
    Nope I did it exactly as the instructions show...I'm really not sure what the exact problem is...I could see a low reading, meaning there is a loose wire or something but high? I dunno....haven't really had time to troubleshoot
    NCLR1
    by NCLR1 » Wed Mar 21, 2007 8:09 am
    Did you use the magnetic rotor bolt or the other magnet? Just curious. Also, have you replaced the computer before? If it's still under warranty maybe you can get a new one... Maybe your wheel distance is not being saved in the memory correctly?
    Tony C
  • Reddog88
    by Reddog88 » Wed Mar 21, 2007 9:13 am
    I used the bolt that came with the kit, and no i have not replaced it...only had it a little while. All this talk inspired me to email trailtech to see if they know whats going on
    NCLR1
    by NCLR1 » Wed Mar 21, 2007 12:04 pm
    Cool, let me know what they say. I clean my connections with a Qtip and alcohol every once in awhile.
    Tony C
  • Reddog88
    by Reddog88 » Thu Mar 22, 2007 2:05 pm
    They've pretty much said its a faulty speedo cable...they're sending me a new one under warantee, I'm going to go through and check all the connections tonight and see if there is any dirt or whatnot causeing a bad connection
    NCLR1
    by NCLR1 » Fri Mar 23, 2007 1:40 pm
    That sounds good. Hope the new cable helps.
    Tony C
  • Vanrock
    by Vanrock » Sat Mar 24, 2007 5:07 am
    One me old CRF150 i had a trail tech um before i smashed it up@ if between the sensors on the bracket for the acual computer gets wet it can cause iregular readings i also thought it was quiet amazing that my 150 could do 245km/hr :P :)
    2007 CRF250R
    NCLR1
    by NCLR1 » Fri Apr 20, 2007 2:44 pm
    I broke my sensor cable where it connects to the caliper during some maintenance. I called Trail Tech and talked to Jeff, he sent a new one that day. Just waiting for it to get here. Good customer service!
    Tony C
  • BillB
    by BillB » Fri Apr 20, 2007 5:31 pm
    As an update to my original post. Trail tech sent me a new cable and my unit is working again. I have no idea why they are going bad. I guess I’m just one of the lucky ones.
    06 CRF 250X
    JD Jetting Kit
    Quick shot APC
    Air Box Mod
    Trial Tech Computer
    Smog block off kit
    Scotts Stabilizer
    Pro Tapers
    AVS F3 Levers
    S1 Hot Cam
  • Dirtclod
    by Dirtclod » Mon Apr 23, 2007 8:35 am
    After a night in the cold mine doesn't work worth a Sh*t!
    by Asmith » Mon Apr 23, 2007 8:36 am
    Dirtclod wrote:After a night in the cold mine doesn't work worth a Sh*t!
    You make your bike sleep outside???? :shock:
  • xman
    by xman » Mon Apr 23, 2007 9:13 am
    I had simular problems with my unit. Trail Tech says every so often the brake rotor will become magnetized to a degree and will through off the pickup magnet. They told me to hit the rotor with a heat gun to de-magnetize it.....now works fine.
    Could you repeat that? In English this time!
Users browsing this forum: Google [Bot] and 7 guests
