Paddle Tire Pressure
    MotoZack318
    by MotoZack318 » Sun Mar 11, 2007 5:30 pm
    I'm going to be running a paddle for the first time (any tips welcome). What tire pressure works good in paddles? Should I use a different pressure for the MSR Ultra Heavy Duty Tube as compared to a stock tube in the paddle? What about tire pressure in the MSR Ultra Heavy Duty Tube on dirt? Any suggestions? Thanks.
    South-Eastern Idaho sucks, so Californians should move somewhere else! :)
    mdmasher
    by mdmasher » Wed Mar 14, 2007 3:59 pm
    9-12 lb. standard or HD tube = same pressure.
    I use the Kings brand with 8 paddels 110/100 18 and have yet to find a sand hill this bike can't climb.
    Pismo beach and Sand Mountain NV. I will try Dumont Dunes next month. Remember to add a link or two to your chain so the cups on the tire will clear the swing arm. I bought anothger chain and run 117 links. stock is 114.
    or buy a rear sprocket a few teeth less. (top end).
    I hear a 49 tooth will fit and clear the swing arm with the stock chain set up. Buy a steel sprocket, they are less expencive.
    05 CRF450X WC,plate&brace.Devol rad. Hand guards.jet.165M #50L.air mods w/twin air filter.Pink.Clarke3.4. CHM pipe.
    80 XR500R old school
    05 Raptor 350 Wifes, Nerf.skids.+
    04 TRX250EX Daughters,Nerf.+
    85 FL350R Odyssey Kick in the A.
    MotoZack318
    by MotoZack318 » Wed Mar 14, 2007 4:28 pm
    ok, thanks. I got a 120 link chain and new sprockets. I heard the king's works awesome, so we'll see.
  • jt1872001
    by jt1872001 » Fri Mar 16, 2007 9:55 am
    i used the king tire and i hated it...it is a great tire for straight line traction,but trying to spin the tire while turning is hard and when you gas it while in a turn the bike wants to stand up and go straight,,i personaly like the chenshing .great traction and easy to stear and drift the rear wheel. i also run at 10-12psi rear and 12-14 front.
    MotoZack318
    by MotoZack318 » Sat Mar 17, 2007 8:43 am
    thanks for the info. i'll try out the king's soon and report back.
