My wishlist.....
  • TJ
    My wishlist.....
    by TJ » Fri Jan 19, 2007 7:21 am
    Good Morning all,
    As I make my wishlist smaller there are some things that have been discontinued. How do I get those removed from my list? There is no little box by them to check to be deleted? I know this is a lame first post but you have to start somewhere right.
    by JAWS » Fri Jan 19, 2007 7:36 am
    Just go to your wish list and select the checkbox next to the item you want to delete, then click the delete button at the bottom.
  • TJ
    by TJ » Fri Jan 19, 2007 12:55 pm
    But there isn't one? Is it just my wishlist? The other things that I have left to buy have the box next to them to be deleted but not the ones that have been marked" Item no longer available"
    by JAWS » Fri Jan 19, 2007 1:15 pm
    pm Ken (use CRFSONLY) and ask him that question.
    by crfsonly » Fri Jan 19, 2007 2:26 pm
    after you log into your account you can select to see your wishlist by clicking on "My Wishlist". this will display your wishlist. on the right side of the display you'll see a check box by each product in your wishlist. check the products you want to delete from your wishlist and then click on the "Delete" button at the bottom of the wishlist display.
    hope this helps.
  • TJ
    by TJ » Fri Jan 19, 2007 3:06 pm
    Ken, I sent you a PM. Thanks.
    by crfsonly » Fri Jan 19, 2007 5:35 pm
    got it...basically if a product that was in the catalog was added to your wishlist and then later was removed from the catalog the item stays in your wishlist but the checkbox to select it isn't displayed. this is to prevent the use of the 'add to shopping cart' button. i didn't anticipate needing/wanting to delete it. so, i'll need to work on this in my copious spare time. ;-)
