by dlpmx » Tue Jan 09, 2007 4:23 pm
Spin the bolt fast with a drill. pull out on the shroud. it will melt out of the tank.Remove the nut/bushing with a wrench. Epoxy the bushing back in. The tank wont leak. this is the fastest and easiest way. Do a search here this has been covered berfore and you can read where others had great luck with this.
Dale
All mods listed in the Garage
